Once again my 3.0 wont start
Old 03-16-2011, 06:29 PM
  #121
3.sloRunner's Avatar
ISR mod success!! lol it runs fine now just overheating which im thinking is a bad thermostat. we'll see
Old 03-16-2011, 06:48 PM
  #122
95blackToy's Avatar
I wish it was that simple for me. Mine just stopped running again. Im gonna try to get a junkyard distributor and see if that fixed it.
Old 03-17-2011, 06:02 PM
  #123
Baggedgmc1995's Avatar
Any luck yet? If you were closer to DFW i have a 94 4runner that I'm about to do a V8 swap on and have all the donor parts you would need. hope you figure it out soon.
Old 03-17-2011, 06:20 PM
  #124
i had a new distributor along with a lot of other new parts so it was easier for me to narrow it down.
Old 03-17-2011, 07:41 PM
  #125
874runnersr5's Avatar
damn dude, your having such crappy luck with this truck
Old 03-18-2011, 06:45 AM
  #126
Team420's Avatar
Dont just go buy a junkyard unit, and toss it in, expecting any different results... Make sure you test the new one before you buy it... I have had so many junkyard parts not work out for me... Hence..the reason the rig was in the junkyard to begin with....
Old 03-22-2011, 08:05 PM
  #127
95blackToy's Avatar
Thanks bagged, appreciate the thought. And 87 yeah i cant get a break with this thing. I have had one problem after another. About the time i start trusting it 100% again it breaks down. I'm tempted to buy a wiring harness and just put a whole new main harness on it. It has to be something electrical because the injectors aren't firing. I want to get another ecm just to be sure that thats not it. Bagged when do you start your swap?
Old 03-23-2011, 04:52 AM
  #128
woodsguy's Avatar
I had some what the same problem with my 92. it turned out to be my O2 sensor. not sure if you've checked yours or not, unplugging it made mine fire right up.
Old 03-23-2011, 02:31 PM
  #129
95blackToy's Avatar
Thanks for the idea but I tried that with no luck
Old 03-29-2011, 06:41 PM
  #130
95blackToy's Avatar
well im about to pick it up again tomorrow. All he did was clean the ECU connectors and a few tries later it started. Im not to confident in that being the whole problem but there is nothing to fix if its running.
Old 03-29-2011, 07:23 PM
  #131
justin_4runner's Avatar
well hope thats the last of the problems and u can get it on the road for more then one day...
Old 03-30-2011, 04:23 AM
  #132
95blackToy's Avatar
Thanks Justin, This thing has been driving me crazy. But i guess we will see. Im probably going to get it today.
Old 03-30-2011, 06:58 AM
  #133
I hope to start in the next few weeks! Going to do the SAS first, found a complete front end off a 85 pu w/ manual hubs. Have to rebuild it also but I have no dead line on the runner. So did you figure out it was all in the wiring harness?
Old 03-30-2011, 10:43 AM
  #134
oldblue88's Avatar
Just read the entire thing about your problem. I had the same problem with my 95 runner, the wires going to distributor were broke in two, too mutch heat i guess i ended up finding a used plug off a parts truck different color wires same plug soldered together, been driving for 6 months now and no problems ,knock on wood . hope this helps
New member, new to computors sorry
Old 03-31-2011, 07:13 PM
  #135
95blackToy's Avatar
Bagged. That sas is going to be sweet! Not sure on thew harness, its at the dealer again and its randomly running again but I dont want to pick it up and it die again, so I gotta start putting some pressure on them because they arent doing much with it now and for some reason wont get the oscilloscope in.
and blue the tech ran direct wires from the distributor to the ECU and apparently it didnt help. Im kinda at a lose with it. Il keep yall posted though with updates
Old 03-31-2011, 07:15 PM
  #136
95blackToy's Avatar
And blue welcome to YotaTech
Old 03-31-2011, 07:50 PM
  #137
that sucks man, how about looking for a truck and pulling the harness, and replacing it, sounds like thats where ur at. i kind of had a problem like this but with a motorcycle and it ended being a short in the harness and after i replaced it ran like a champ... i know its a big job but im thinking thats where u might be.
Old 04-01-2011, 06:50 AM
  #138
95blackToy's Avatar
I could do it and I want to get a donor t100 and do a 3.4 swap but if things with the dealer dont work out then I probably will do either the harness or the swap.
Old 04-01-2011, 07:19 AM
  #139
rand725's Avatar
wanting to buy 3.0 yota engine harness part#82121-35-261f
anyone have 3.0yota 1993 4x4 engine harness to sell.Need one to get the yota on the road.Part#82121-35-261f
Old 04-01-2011, 04:39 PM
  #140
95blackToy's Avatar
WTH Thread jack^^^ If anyone offers up a harness for sale Im buying it.
Quick Reply: Once again my 3.0 wont start
