Ok so my engine blew out
Here is a 3.4 motor and tranny dirt cheap on craigs list
http://lexington.craigslist.org/pts/631254650.html
#28
And ok i started taking the engine out i disasemble the air box and it was full of oil i dont know it was werid im prety sure its not supose to be like that lol and my i started taking the bolts of the transmision how many bolts hold the transmision? And also what else i need to disconect?
#29
as far as taking the engine out, disconnect and label the wires and vacuum tubes just incase you end up puttinga 3.slow back in again, makes it a hell of a lot easier. i have not done a motor swap on my truck nor have had to pull the engine but taking the hood off would help, as well as taking the radiator, and possibly the upper have of the intake manifold. Might help with some clearance issues with the hoist.
good luck with whatever you do!
#31
Labeling will be a lifesaver whether you swap or not. Take LOTS of pictures, from every angle you can, as they will make the reassenbly significantly easier to deal with.
I'm a huge fan of the 3.4, since my swap, but do what you are the most comfortable with.
#35
06-01-2021 01:51 PM
Seattle_Sign_Guy
07-12-2015 12:38 PM
