Oil Leaking from bolt
I have a 1991 Toyota 4WD with a 22re engine.
There is oil leaking from a bolt next to the crankshaft pulley. I circled it in the photo. Any ideas? Could it be the oil pump O rings?
Oil leaks from around bolt when engine runs.
Looks like you or someone replaced the timing chain, cover, etc. It appears maybe it's not torqued enough compared to the adjacent similar bolt.
What is the torque for this bolt?
According to the Toyota FSM for 1993 4Runners and P/U, it's 9 ft-lb. Yeah it's light since the oil pump mounts to the timing chain cover which is aluminum but according to the picture, the washer doesn't look compressed like the other bolt. Good luck and hope this is it.
gibbonsballer10
10-26-2023 07:13 AM
