Oil coming out of throttle body.... Help!
Old 12-18-2010 | 12:30 PM
simpsons721's Avatar
So i recently posted about how my car won't start took off the intake and there is oil in my throttle body and when I open the throttle it drips out.
First how screwed am I and what can I do, are the headgaskets blown?
Old 12-18-2010 | 01:18 PM
Please help
Old 12-18-2010 | 02:03 PM
rworegon's Avatar
Ummm. Some specifics like year, engine, etc. will help.
PCV valve not working properly?
Old 12-18-2010 | 02:29 PM
Homeless dog & truck's Avatar
From: From FEMA region #8...I quit what a bunch of girls YT
oil
Its probably a bad case of blow by, do compression test, in Boulder @5000 ft, a good engine would have about 155 lbs.if its a 22R
Old 12-18-2010 | 04:33 PM
My car info is in my signature, would this cause my car not to start? Pcv needs to be changed but a pain to do
Old 12-18-2010 | 04:37 PM
rworegon's Avatar
I stand corrected. But, I do not see your signature at the bottom of your posts...hmmm.
Old 12-18-2010 | 05:18 PM
Umm ya I don't know because I'm on the mobile version but 94 3.0 3vze
Old 12-18-2010 | 05:28 PM
Its toast
First to the guy who asked what year and engine...do you really think that there are engines where its OK to have oil in your throttle body??? I just concurred with the machine shop where I hang on cold days....your engine is toast. Theres only one way oil can get in there and thats thru the valves via bad rings. So just run it till it quits and save your $$ for a new engine, oh and yes oil can come thru the PVC but it would just get sucked into the CC if engine was in decent shape.
Old 12-18-2010 | 05:41 PM
rworegon's Avatar
I agree, it is NOT ok or normal to have wet oil in the throttle body. Yes, I know that. A quick search of this board and others yielded several ideas (while not specific for this engine): 1) compression blow by and 2) PCV valve issues.
A valid compression test with low pressures would lend support to your hypothesis.
Old 12-18-2010 | 05:43 PM
That's what I've read rings are bad can that be fixed? And ya my car won't start so it is dead.... I just paid 100 for registration.....
Old 12-18-2010 | 06:10 PM
James Woods's Avatar
Well if he had a turbo 22re it could mean that his turbo is bad and the motor could be fine. But I do agree there is lots of blow by if there is oil DRIPPING from the throttle body, how is it on power? I would think with that much oil, you should have some pretty low compression and would be low on power.
Old 12-18-2010 | 06:15 PM
help
Well there is a possibility that if your PVC was so plugged to the point of no flow (AIR pRESSURE), oiL could get into the TB/plenium but if its plugged, its prob do to so much oil gettig up to the valve itself. and do to the fact it won't start anymore theres prob. no compression. sorry for your loss, just calling a spade a spade I love my truck too
Old 12-18-2010 | 06:25 PM
^Duh I must have read over the engine not starting part.
Old 12-18-2010 | 06:26 PM
No i need all the honest info possible, it just sucks....
Old 12-18-2010 | 06:46 PM
rworegon's Avatar
Ok, on the non-starting issue: Have you checked your fuses? It seems you had a thread in June 09 with a similiar non-starting issue and it was because your EFI fuse popped as diagnosed and repaired by the dealer.
Old 12-18-2010 | 06:52 PM
Didn't check the fuse again because this time it sounded differently while trying to start, but I will, I'm gonna try a compresion check tommorow and go from there.
Old 12-18-2010 | 06:56 PM
rworegon's Avatar
Good deal. Just to be safe take a look at all the fuses.....
Old 12-19-2010 | 11:06 AM
88toyblackjack's Avatar
Yep, doesnt sound good. At the very least, a valve job is in order. As expensive and detailed a job as removing/replacing the heads are on this engine, it would be a gamble to not consider an engine rebuild. As for the no-start, you may be getting enough blowby pressure into the intake system to affect the AFM reading. Mine did. A real PIA to start everymorning. Out of neccesity, I had to continue running mine 2.5 hrs up and back everyday, as well as running all day on a wetlands project in 4wd. Mine was so bad, I had to run a catch bottle on the vent hose from the valvecover to the TB, and had to run seafoam every weekend thru the intake. I was catching up to a qt of oil and re-using it every 60 miles. Yes, when I get back stateside, a 3.0 rebuild is #1 priority
Old 12-19-2010 | 06:21 PM
ya im thinking im in really bad shape..... i have spark, i dont think it is a fuel problem because my car wont even start with starter fluid. I need to do a compression check next.
I was checking how much air my throttle was sucking and it didnt really feel like much what diagnosis does that give?
Old 12-19-2010 | 11:04 PM
sam333's Avatar
Yes it is OK . Depening on how the throttle body is set up, it is common even on new engines to have some oil in the throttle body.
It depends on how much oil.
If you have high milage and are burning alot of oil you probably have blow by from worn cylinders /rings.
Over filling can cause alot of oil being blown out of your PCV also.
On any throttle body that has the PCV hose near the throttle plate your going to have some loose and baked on oil.
The oil may or may not have anything to do with your starting problem.
Are you burning alot of oil?
How many miles on the engine?
