O2 sensor code on 3.0 with new a sensor
Hey everyone, sorry if this topic has already been addressed, I'm a newby. I changed the exhaust on my 93 3.0l 4runner and I'm getting an O2 sensor code when I short the diagnostic leads. The shop had to use a torch to get the sensor out of the old exhaust so I changed out the sensor for a universal NTK one (the same one that I had on previously with no prob) and still couldn't clear the code (by pulling the EFI fuse). I then put a new high flow catalytic convertor on, thinking that removing the cat when i changed the exhaust may have caused the problem but the code still will not clear. I'm running out of patience and $$$, anyone have any ideas?? Will having the code read with an actual OBD1 diagnostic computer tell me anything more than shorting the leads? thanks alot
Originally Posted by suprathepeg
Check for a short in the wires from the O2 to the ECU.
Ya Code 21. For us cars, that means the rear bank, rear = right hand = odd bank.
With the truck cold, plug a multi-meter into the o2 wire so you can read the voltage output.
Crank the car & immediately start driving around. It should take about 30-45 seconds for it to come up to temp. They can take up to 2 min idling, and sometimes never come up to temp. If it doesn't come up to temp- the sensor is lazy & has poor responce time.
Also, when it has reached temp, watch the output of the o2 sensor. It should be bouncing between 0.4 & 0.55 volts. The ECU will throw 21 if it stays below .4 volts over 1500rpm & go into open-loop mode. (The lower the voltage, the leaner.)
Under either of those conditions, the thing is toast - replace it with a $30 generic splice in o2 sensor & for that cheap, ya might as well do both!
Most of the time, Toyota did not use a heater circuit on their main o2 sensors on OBD-I. They did on cars equipped with a post-cat o2 sensor. If the 3vz-e broke that trend & has headed main o2 sensors - the generic Toyota spec is 11-17ohm when you disconnect the o2 harness & check resistance across HT & B+.
Tho it does go against "obvious" troubleshooting B/C only one bank has a proven sending a lean code - check for vacuum leaks after you replace the o2 sensor. Toyota OBD-I is notorious for letting problems slide, and hell WILL freeze over before OBD-I Toyota throws a lean, or rich code most of the time.
My o2 sensor's gasket rotted out which I was totally unaware of and as I was driving down the highway, guess what worked its way out? You wanna talk about loud. I thought the pipe had rotted again, but it was just that nuts had backed themselves off due to vibration. It never threw a code even dangling in mid air hanging by the wires. I bought a new sensor, since it was off already, cleaned up the rusty threads with a die and I was done. I figured after 12 years it was time.
