No Hazard lights but blinkers work fine (88 4x4)
1988 toyota 4x4
While fixing my blinkers I tested the hazard button to verify all lights are working.
What I found was my hazard button no longer activates.
Both sides and all lights work normally when I activate a turn left or right and that is not an issue but what I've read is all these should be going through the hazard switch, where mine doesn't appear to do anything.
Anyone have experience in this situation?
do I replace the switch or is there a separate hazard relay?
I could have told you exactly what to check on this exact post, if you had a MORE complete description of problem.
Why were you fixing your blinkers if the hazard button were the problem?
What makes you say the hazard button no longer activates?
What else do not work?
What else still work?
Ah that explains the other guy's title, was wondering about that. At least we know he searched. Yes, probably your haz switch, it controls two circuits. Checked fuse already I hope. See diagram I posted here - https://www.yotatech.com/forums/f120.../#post52435179
1986-1988, most likely same as 1984-1985 4Runner's too.
The following users liked this post:
old87yota (12-15-2019)
johnson1987
12-19-2009 05:33 PM
pattycakes77
09-03-2007 10:46 AM
Beartracker
03-04-2007 05:01 PM
