NO Compression.....NONE!
I used the search and read a few posts but didn't see anything that sounds to be the same as mine....
So I have been trying to get a 22RE in a 1990 4runner running so I can swap it over into another project I'm putting together. Picked it up from someone I know and he said it has just been sitting around for a long time and he wants it gone, but doesn't know why it doesn't run. Well it was getting spark, it was getting fuel, timing is on....so I checked the compression. Cylinders 1-4 dont move the compression checkers gauge in any manner what so ever... Checked timing again and again. Valves are closing on the compression stroke. So the other options, correct me if I'm wrong, would be valves or rings. BUT in my head if you have a bad valve or rings there still should be something register on the gauge then die off right? Am I missing something here? Any pointers, direction, anything! It has me stumped.
I also had zero compression in #4. After 200k with no adjustment, all the valve clearances were tight but there was NO clearance on #4 causing it to never fully seat. Valves stretch with time and valves won't fully seat. I bet a valve shim job will fix you right up.
if someone else was fiddling with the engine earlier it requires a lot more of a check for the fundamentals. put it on a stand. shine a light down the spark plug holes and look at the thread if you can. idiots can literally strip the spark plug threads out of an engine if overzealous tightening the plugs or putting the wrong ones in. crank the engine while you're looking in the holes to make sure all of the pistons are there. If that all doesnt find the issue, pull off the oil pan to make sure its still got a full rotating assembly. get another compression checker, or get a shop to do it for you. make sure its not the tool you're using. check and make sure they didnt just pull off the heads once, and put it together without a head gasket. If there isnt a head gasket, or if all else fails, pull the head and make sure the valves and valvetrain are still on.
thanks everyone for your pointers. I did check the gauge on another motor and it is working correctly. i also already checked to make sure there were actually pistons in there, they are going up and down. I read somewhere that somebodys timing chain had broke causing all the intake valves to bend and get all messed up. I'm going to have to pull the head off and check to see if the valves are all in fact in one peice and not all jacked up. But right now its sounding like I'll be replacing some valves next weeked. WEEEEE!
So I got around to pulling the head this weekend, intake valves all have a nice little flat spot along the lower side and you can see light through them. So I priced out getting it machined and new vavles and springs, that crap crap adds up real quick! Found a rebuilt head on ebay for 170 including all new valves and springs with a one year warranty, that seems like the way to go.
