No blinkers
No blinkers
I got a 1995 SR5 pickup 5spd with a 3.0 that needs some help. Today my gauge cluster went out so i fixed that(ended up being a fuse). Now i dont have any blinkers but the hazards work(except the rear drivers side) but the bulb isnt burnt out. I just started with these problems today when i hooked up to a trailer. Starting to think its cursed! Any ideas would be appreciated. Also my windshield wiper switch is either bad or the pump is bad cause that stopped working a few weeks ago. Wondering if it could be the switch in the column? Light switch on column works, horn, cruise, etc.
Have you checked the fuse for the turn signals?? Different then the Hazard lights
Clean the socket of the light not working they corroded as well as new bulbs exposed to the air.
Scotchbrite for the bulbs a fitting brush of the correct size works good for the sockets
Perhaps it blew when you plugged in the trailer lights.
easy to pull the windshield washer tank and test the pump and at the same time test if you get voltage when the switch is closed.
If you don`t have a multimeter good time to invest in one.
just swapped the fuse and still nothing. I bet i bumped a wire when i was playing with the gauge cluster fuse. Anyone have a wiring diagram or wire color?
Im willing to bet that the drivers side rear hazard isnt working due to a broken wire, but i cannot for the life of me figure out why i have no blinkers. Even if the lights werent connected, the turn signal switch should still work and the indicators should still flash.
narrowed it down to being a problem with the integration relay. Is this a separate relay or do you have to replace the entire fuse box? Guessing a dealer only part?
Scotttekoch
09-28-2015 10:30 PM
landes94
08-16-2015 12:20 PM
