Nicest Runner I've EVER Seen
#45
Location: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
Just wondering, why would you cut a chunk out of the back of a 4runner? They aren't that long to begin with and I'd think it'd do more to limit your carrying capacity than it would do to improve your departure angles. I could see doing it to a long bed truck or something like that.
If you don't understand you aren't taking off steep enough . Its not about being long, its about the over hang from the point the shackle attaches to the frame to the edge of the rear end. Departure angles are significantly increased be eliminating that. Probably will gain 20* + in departure angle by bobbing the runner.
Awesome angle, and nothing a stock 4Runner couldnt do...
now coming off a ledge...
#46
#50
Toyota
It is a Pro comp 4 in Lift------------The kit has the Trailing arms with it
This one could be bought~~~
#52
Jnkml
07-06-2015 01:20 PM
Suprarossa
07-06-2015 05:21 AM
