Nice e-bay find
Nice e-bay find
I can't figure out how you guy's get the picture's from ebay and put them here but if you go to motors and search 4runner its on the second page about 1/4 way down. It doe's look pretty nice and it was well done
View larger picture
Current bid: US $4,550.00
Reserve not met
Your maximum bid: US $
Place Bid
(Enter US $4,600.00 or more)
Get low monthly payments
End time: Dec-01-07 18:12:26 PST (2 days 2 hours)
Shipping: Buyer responsible for vehicle pick-up or shipping. Vehicle shipping quote is available.
Sells to: N. and S. America
Item location: Alanson, MI, United States
History: 12 bids
High bidder: r***w( 0 )
You can also: Watch This Item
Bid with Bid Assistant
Get mobile or IM alerts | Email to a friend
Listing and payment details: HideShow
Starting time: Nov-21-07 18:12:26 PST
Starting bid: US $1.00
Duration: 10-day listing
Payment methods: Cashier's Check (certified from US or Canadian bank) or money order,
Cash (in person)
See details
Meet the seller
Seller: kcleary06( 20)
Feedback: 100% Positive
Member: since Sep-18-06 in United States
See detailed feedback
Ask seller a question
Add to Favorite Sellers
View seller's other items
Contact the seller instantly
Buy safely
Check the seller's feedback
Review the vehicle history report
Get tips and advice in the Buyer Checklist
This vehicle is eligible for up to $20,000 in Vehicle Purchase Protection
Seller's DescriptionHistory ReportShippingFinancingBuyer Checklist
1995 Toyota 4Runner LIMITED Print Version
Title: STRAIGHT FRONT AXLE, LOCKER, EXO-CAGE, NEW, CLEAN!!
Mileage: 138,005 miles
Vehicle Information
VIN: JT3VN39W0S0207494 | Get the Vehicle History Report
Inspection: --
Warranty: No
Vehicle Title: Clear
Condition: Used
Features
Body Type: SUV Engine: 6 Cylinder 3.0 Liter Exterior Color: Black
Transmission: Automatic Fuel Type: Gasoline Interior Color: Tan
Standard Equipment
ABS Power Steering AM/FM Radio
SR5 4 Wheel Drive 6 Cylinder 3.0 Liter
3.0L V6 4WD
Optional Equipment
Cassette Power Door Locks Cruise Control
Power Windows Leather CD
Moonroof
Description
Vehicle Description
TOYOTA 4RUNNER ROCK CRAWLER/ DAILY DRIVER
FRONT AXLE
* 1984 Housing-full truss
* Trail-Gear gusset kit
* Marlin Crawler inner axle seals
* Trail-Gear rebuild kit
* V6 Third member, open differential, 5.71 precision gears, all new bearings, Trail-Gear triple drilled flange
* IFS hub modification
* Brand new V6 calipers and pads from NAPA
* Brand new FJ 40 rotors from NAPA
* Trail-Gear Hysteer kit
* Hydro-assist steering
* Trail-Gear differential armor
* Trail-Gear low profile differential plugs
* Trail-Gear u-bolt flip kits
* Trail-Gear stainless braided brake lines/ new factory hard lines on calipers
* Trail-Gear 1" wheel spacers
* New third member bolts to replace studs(stronger)
REAR AXLE
*1999 Tacoma e-locker housing
*E-locker third member, 5.71 precision gears, all new bearings, Trail-Gear triple drilled flange
*Ruff Stuff caliper brackets
*Brand new tacoma front rotors from NAPA
*Brand new tacoma front calipers and pads from NAPA
*Trail-Gear wheel bearings and seals
*Trail-Gear differential armor
*Trail-Gear low profile differential plugs
*Downey e-locker cable conversion kit
*Trail-Gear u-bolt flip kits
*New third member bolts to replace studs(stronger)
*1/2" wheel spacers
*Earls Plumbing stainless braided brake lines
FRONT SUSPENSION
*Homemade front spring hanger
*89-95 Toyota pickup rears up front, overload removed, with 3 leaves from a jeep wagoneer pack
*Ruff Stuff 6" shackles
*Trail-Gear 14" shock hoops
*Pro Comp es9000 shocks, 15.52 travel, pn# EXP-936000
*Energy Suspension poly shock bushings
*New spring bushings, homemade spring clamps, 9/16" grade 8 hardware
REAR SUSPENSION
*Homemade spring/ shackle hangers
*57" Jeep Wagoneer 5-leaf rear springs, overload removed, one leaf added
*8" Homemade shackles (3/8")
*Heavy duty upper shock mounts
*Heavy duty Ruff Stuff lower shock mounts
*Pro Comp es9000 shocks, 14.58 travel, pn# EXP-934000
DRIVESHAFTS
Front-
*Trail-Gear 12" slip
*Rear single cardan yoke
*Re-tubed with schedule 40 pipe
*New precision u-joints
Rear-
*Stock slip yoke
*Front cv at transfer case
TIRES/WHEELS
*5 37x13.50x15 Mickey Thompson baja claw radials
*5 Cragar soft 8, 15x8, 4.5 backspacing
MOTOR/TRANSMISSION/TRANSFER CASE
MOTOR
*3.0 V6, 138,000 miles
*Brand new cylinder heads/ head gaskets
*K&N air filter
*New stock muffler, new 2 1/4" pipe
TRANSMISSION
*Stock A340H
*Shifts smoothly
TRANSFER CASE
*Stock
*4wd works well
All parts listed above have less than 1000 miles on them. I wouldn't be selling this truck but I am moving and this isn't the most practical vehicle for me right now.
The front clip has been removed and replaced with tube. The rear wheel openings have been opened up and plated in with 14 gauge diamond plate. wheel openings were then coated with spray on bedliner.
All suspension and axle components have been sandblasted and painted with PPG DP epoxy primer(which is the best bare metal primer in my opinion) and then topcoated with a 2 part PPG paint. The frame was also cleaned up and painted.
The body has had minor surface rust repaired and then painted by me. There are a few imperfections in the form of minor dings and scratches. Otherwise the body is in great shape.
The interior is very clean for the year. The only problems are a crack in the dash pad, a cracked quarter panel trim, 1 small tear in the driver seat, and 1 small tear in the rear seat.
I am including the spare parts I have for this truck which include 1 rear axle shaft, 1 long side front axle, 1 short side axle, 1 birfield joint, 1 left knuckle, 1 right knuckle, 1 spindle, and 1 locking hub.
I have tried to give the best description possible but if you have any questions or want specific pictures of anything please ask.
THANKS FOR LOOKING!
Select a picture
02424
What's your Credit Score? 720? 650? Find Out From Experian.
Questions from other members
Q: probably one of the coolest 4runners ive seen in a long while!! nice work. what kind of gas mileage do you get with it? i know its a trail rig not designed...more
Answered on Nov-22-07
A: Thank you. I haven't actually figured out the gas mileage but if I had to guess I'd say right around 12mpg.
Q: is this rig geared too low to be considered a daily driver as well? have you run it on the open road, or just used it for crawling?
A: Thanks for the question. The truck originally came with 4.88 gears stock. That is the lowest gears toyota put in from the factory. When you put the new...more
Shipping, payment details, and return policy
Pickup & Shipping
Buyer is responsible for vehicle pickup or shipping. Vehicle shipping quote is available.
Seller's payment instructions
Payment to be received upon pickup or within 3 days by paypal. Buyer pays all shipping costs. I am flexible and can help with shipping arrangements.
Deposit via PayPal
US $500.00 within 48 hours of auction close.
Payment methods accepted
Cash (in person)
Full payment
Required within 3 days of auction close.
eBay recommended services
· History Report - get a vehicle history report and protect yourself from hidden problems
· Shipping - get free shipping quotes and information on options to pick up this vehicle
· Financing - learn about lending choices
· Buyer Checklist - review steps to take to make a safe, successful purchase
Ready to Buy? Live Help
Item title: Toyota : 4Runner
Place a Bid
Place Bid
You will confirm in the next step.
eBay automatically bids on your behalf up to your maximum bid.
Learn about bidding.
What else can you do?
Back to home page|Report this item|Printer Version|Sell one like this
Seller assumes all responsibility for listing this item.
About eBay | Community | Security Center | Buyer Services | Policies | Government Relations | Site Map | Help
© 1995-2007 eBay Inc. All Rights Reserved. eBay and the eBay logo are among the registered trademarks of eBay Inc. Kelley Blue Book® and Blue Book® are registered trademarks of Kelley Blue Book Co., Inc. Other trademarks and brands are the property of their respective owners. Some automotive images © eVox Productions LLC, all rights reserved. Use of this Web site constitutes acceptance of the eBay User Agreement and Privacy Policy.
View larger picture
Reserve not met
Place Bid
History: 12 bids
Cash (in person)
See details
Meet the seller
Buy safely
Vehicle Information
Inspection: --
Warranty: No
Condition: Used
Features
Standard Equipment
3.0L V6 4WD
Optional Equipment
Moonroof
Description
Vehicle Description
FRONT AXLE
REAR AXLE
*1/2" wheel spacers
FRONT SUSPENSION
REAR SUSPENSION
DRIVESHAFTS
Front-
Rear-
*Stock slip yoke
TIRES/WHEELS
MOTOR
*K&N air filter
TRANSMISSION
*Stock A340H
*Shifts smoothly
TRANSFER CASE
*Stock
*4wd works well
THANKS FOR LOOKING!
Select a picture
02424
Pickup & Shipping
Deposit via PayPal
Cash (in person)
Full payment
Place a Bid
Place Bid
FS[GreatLakes]: Toyota collection part out
88sasturbotoy
08-11-2015 02:56 AM
HookahRoo
07-20-2015 08:06 PM
scottyg486
07-19-2015 06:34 PM
sojourner567
07-16-2015 09:52 PM
37x1350x15, cable, craigslist, differential, downey, drilled, ebay, elocker, fj40, mickey, open, tacoma, thompson, triple, yoke
