New Truck, Trying To Figure Out Noise (Video Included)
I just bought a '88 22RE RWD Pickup with 136k miles on it. Engine runs well, completed a rather in depth tuneup on it and all is purring along nicely. However I'm experiencing a noise while driving that I think is probably the differential..
The Facts:
I'm never done any differential work before so I'm not sure what constitutes normal and what's not.
VIDEO LINK: https://www.dropbox.com/s/8aeh1k8k53..._0375.MOV?dl=0
The Facts:
- Sounds like a wurring, grinding noise.
- Noise is only present when moving AND in gear.
- Noise increases when throttle is applied but NOT when in neutral. Engine revs fine in neutral and no noise present.
- Transmission shifts pretty smoothly and through all gears.
- Removed drive shaft from the differential and inspected pinon nut. Appears to be OK and tight.
- Replaced Diff fluid. Very fine metal shavings attached to plug, but very very minimal in amount. Like, I had to pick it out with a tooth pick.
- Backlash in the diff is present, maybe 1/4" in either direction?
- Jacked up rear, put truck in neutral and spun rear wheels. Can for sure hear bearing noise but I'm not 100% sure it's what I'm hearing on the road.
LittleRedDevil
12-23-2011 11:53 AM
HaveBlue
10
02-15-2003 10:41 PM
