New Rear Bumper From T.G. With Optional Side Mounts
Old 11-30-2009, 06:04 PM
BigBluePile's Avatar
Hey Harley, did your move you pics around in photobucket?
Old 11-30-2009, 06:05 PM
olharleyman's Avatar
Originally Posted by jrobertson4runnner
hey man, where did you get the mount for yorunnner;51295891]hike the idea, just tryin to figure out a good way to mount it.
Thanks.
That you can pick up at any truck stop or CB shop very common mount
Old 11-30-2009, 06:10 PM
Originally Posted by tmcorbin
Nice, Good looking toys in the background also, that lathe and mill is exactly what I am looking for. Is that a pan in the background, HD in the red, cant really tell from the pics.
GOOD EYE!
YEA that's my 55 Pan original motor frame and trans but the rest is mostly the the parts I got with it when I bought it from the original owner so I decided to use all of them and streached the tanks and added the tail dragger rear but still fenderless on front with the springer
Yea did they disappear for some reason if I try to edit or preview it just wacks out my posts so I end up redoing the same post 4 or 5 times to make it understandable anybody else getting that issue?
Old 11-30-2009, 06:11 PM
Originally Posted by olharleyman
Yea did they disapedisappear
Yeah man, from the first couple pic posts you put up.
Old 11-30-2009, 06:27 PM
  #25
weird I see all of them.
Old 11-30-2009, 06:30 PM
  #26
I dunno man, I can't see them.
Old 11-30-2009, 07:07 PM
  #27
OK re-posted them are they working now?
Old 11-30-2009, 07:34 PM
  #28
rangerruck's Avatar
nope.
Old 11-30-2009, 08:01 PM
  #29
I can't figure this out I see them all fine but you guy's are saying you can't see them is it april 1st? lol
Old 11-30-2009, 08:17 PM
  #30
Hey man they're working now!!! I'm diggin the hi-lift mount, but I'd be worried that thing would get buried in mud or just badly corroded sitting there.
Old 11-30-2009, 09:00 PM
  #31
YEA that's what I was thinking so I will try it out on the rear and see what that looks like then go from there.
If it looks bad there as well then I will go back to the idea of building a mount off the front bumper or if I get it, I will build one off the stock tire carrier rack after I retro fit it to this truck which is what I wanted to do from the start but thought I would give this a try and see what happens.
Old 11-30-2009, 09:19 PM
  #32
I carried my hi lift on the rear bumper for years and the damn thing never worked when I needed it. I had to soak it with oil eveytime. However, Ive found that having one or two, even three spots to rigidly mount the jack makes it easier to tailor to your needs.
Old 11-30-2009, 09:45 PM
  #33
Well my original idea was to mount it off the stock swing out tire carrier mounted on the top bar behind the tire once it is mounted.
I found a perfect 1990 tail gate with the carrier and it is as complete as if it came from the factory for $100 just got to find time to pick it up and switch it out on my 93 so I am going to do the stereo set up at the same time so I can set the inside support behind the rear panel killing two projects at one time.
Old 12-01-2009, 07:00 AM
  #34
Fossilized
Staff
dropzone's Avatar
I have shop Envy!! that lathe would be fun.
Old 12-01-2009, 10:53 AM
  #35
jrobertson4runnner's Avatar
Thanks man. Ill do some looking.
Old 12-01-2009, 04:24 PM
  #36
OK well here she is installed some of the pics may not be the best but camera just don't seem to like night time
TMCORBIN
THESE ARE FOR YOU MIGHT BE ABLE TO MAKE IT OUT A BIT BETTER
Old 12-01-2009, 04:36 PM
  #37
Dude, did you notice the small ding in your tailgate?
Oh and the bumper turned out great!
Old 12-01-2009, 04:38 PM
  #38
GenXr's Avatar
looks good. How did the install go? I installed mine last night and had to grind off over a 16th inch of metal on both mounting tabs. I was very grateful I didn't powder coat the bumper!! I would have been a sad person after beating on it like that to get on the truck.
Old 12-01-2009, 04:45 PM
  #39
It was a pain in the ass the bolts inside the frame gave me hell for a couple hours other then that it was not a problem, but I did notice that the bumper seems to be about 1/8 different side to side but I am going to live with that and as for the paint I am going to leave it as is for now but I am going to try some POR 15 on both the front and rear bumpers and see if it holds up better then or as good as powder coating if not i will take them to the shop throw them in the oven (6x8 walk in)and bake them for about 45 mins at 400 degrees
Old 12-01-2009, 04:56 PM
  #40
GenXr's Avatar
Yes, mine is off centered by about the same amount. I'm going to have to grind a little off the left vertical piece to clearance it for my tail gate. It catches by a hair...just enough to scuff the paint on the tail gate.
If you POR-15 it you should probably strip the rattle can off and prep the bare metal with metal-ready, then 2 coat with POR-15 per instructions. That stuff works great as long as you do the prep work right. Otherwise, it'll peel off in sheets. i did my frame with it and it looks pretty good....but it does need a top coat if it's in direct sun light.
I noticed you had trouble painting the same areas I did on mine! those are a PITA to get covered well.
Looks good though. I'll have to get some pictures of mine for you to see.
Quick Reply: New Rear Bumper From T.G. With Optional Side Mounts
