New Here.. in progress head gasket help needed
Hello!
This is a great forum and I've found it very helpful so far.
I'm working on my wife's 94 4runner. It blew the headgaskets after overheating a couple weeks ago and I decided to fix it myself. So far it's been a decent experience (I'm used to working on older engines, so this has been a learing experience)
here's where I stand:
The heads have been cleaned and surfaced:
Here's the question. I want to reinstall the camshafts myself. When my machinist took off the lifters he found these washers sitting on top of the springs:
Now, from my manual it says I should be using shims to get the gap right between the cam and the lifters (shims under the lifters)... This was a "rebuilt" engine when we bought it, and I'm thinking these washers were a poor substitute. Can anyone give me the procedure for figuring out the shim size I need and where to get them?
Thanks,
Nate
Thanks,
Nate
Geezus, what a stupid thing to do! I believe www.engnbldr.com has the shims you want:
email: engnbldr@engnbldr.com
If not, then you may be stuck with the dealer...
Here's a 93 FSM too: http://personal.utulsa.edu/~nathan-b...fsm/index.html
Looks like the proceedure starts here on page 13 of 41 (EG2-61) http://personal.utulsa.edu/~nathan-b...68cylinder.pdf
excellent! That's much more detailed than my haynes manual.
It just makes me wonder why anyone would put those washers in there? Is that what the shims are supposed to do, take up that space? Do I need to get my camshaft in there and chek with a plastigage?
Washers???
Are you sure those are not the washers from the head bolts and they just fell into the head when the bolts were removed? I wish I could have been that lucky. I dropped one into the head and it fell into the oil pan. I ended up pulling the oilpan to get it out...
Valve lash adjustment
zd92655
03-06-2022 12:58 PM
voiddweller
19
05-02-2016 09:10 PM
