New head doesn't match my 87' 22RE
Just got a call from J&C Enterprises, they received my old head, said it was indeed from a 22r, pre-1985 block.
So I've got a bazilian questions now. I really don't know much about the 22r compared to the 22re, except that the latter is fuel injected. So if it's a pre-1985 engine it was retrofitted with fuel injection, right?
Curious - did your block have a knock sensor installed?
Anyway.. You're in the situation you're in:
1) see if they can swap you for the correct head. Early heads come in 3 flavors:
a) No EFI holes or bosses (carb'd only)
b) EFI bosses, no holes or threads (can be drilled and tapped)
c) EFI holes and bosses
You want C. They may be hard to find as pre-85 trucks didn't come with EFI. You can sometimes find these heads with the Celica croud. If you're lucky, they'll have the right head to swap you. It's important that they pay attention to the mounting holes on the intake side of the head.
IF they don't have it, get your old head shipped back and have it cleaned, decked, and rebuilt by a machine shop. It should run around $200 with the valve job and reassembly. Feeling ambitious, add engnbldr's .5mm over stainless valves...
Did you look to see if your's was the laser block as shown in the link I posted? That will tell you if it is the older block for sure. You can also measure the deck height on yours for further confirmation. Measurements are also in the link.
#25
Good info fellas. I ordered another head yesterday from J&C, I'm assuming they are aware that the head I had accepted EFI, but I guess I'd be an idiot to assume anything. That really sucks that my truck doesn't have the original 22re, I know there isn't a huge difference, but at least I would know what replacement parts to buy. Man, I thought I got a killer deal on this truck. Hindsight=20/20
If I have to, I'll take it to Noland Heads here in KC. My old head was cracked in four places. But other than that it's fine.
#26
It's not a big deal, unless you go to rebuild.. Pretty much everything else is compatible. No performance differences.
#27
Thanks guys, you been a big help!
crashburnoveride
07-10-2015 06:39 AM
icentropy
07-09-2015 02:12 PM
