New Engine won't start 1993 3.0
Old 12-22-2013 | 01:38 PM
colomoose's Avatar
1993 Pickup 4x4 3.0
I installed a new engine, had the block bored and heads redone.
The engine turns over and almost starts, sputters a little and dies.
I have double checked the vacuum lines and pulled the front of engine back apart to check timing marks all fine.
I have spark and I have gas just need them to work together.
Any help would be great
Old 12-22-2013 | 07:05 PM
1986pu's Avatar
Spark timing....?
Old 12-23-2013 | 11:44 AM
earlycuyler88's Avatar
It sounds like your distributer might be off by a tooth or two, i would try setting the engine to tdc and pull the cap off the distributer and make sure the rotor is pointing towards the #1 wire
Old 12-26-2013 | 10:25 PM
Gevo's Avatar
Yes. Start by adjusting your timing from one extrwme tot the othwr aandsee what happens.
Crazychris1871
06-27-2016 10:38 AM
Alex Bessinger
06-28-2015 10:05 AM
newzingo
06-24-2015 01:50 PM
nyk08trx
06-18-2015 09:01 PM
Corey
06-10-2002 04:23 AM
Quick Reply: New Engine won't start 1993 3.0
