New AFM, Timing Issues
Hey guys,
Having some timing and power issues with my 22re, and would love some extra input. I just replaced all the timing chain gaskets, oil pump, front main, oil pan, and somehow ran into a timing issue.
I set the timing to 0*, and the distributer is cranked as far clockwise as possible. Idle set screw is loose, will not advance idle above 800rpm
I replaced the AFM box with one off a 89 (ish) 3.0 motor, can't seem to get it adjusted correctly.
No power under 3000rpm, and I'm not sure where to start here. Any help would be appreciated
PutzRunner
07-06-2016 11:52 AM
