New 95 HELP!!*
#26
I didn't see any mention of white smoke in previous posts. Is it out the exhaust? Then it would be antifreeze. Check your oil (change it) and look for water in it. Also look at the oil fill cap see if there is water vapor (white residue) on the underside of it. White smoke is one of the indicators of a blowen head gasket. If you have or can rent/borrow a compression tester that would tell you and us a lot. Most parts stores rent them fairly cheap. You could probably buy one for $20 or so from harbor freight. If its a head gasket you probably got a lemon and should see if you planned future engine swap is doable now. Good luck keep us posted.
#30
#31
Haha outta sight outta mind right?
I would get headers but if I do a engine swap why put money in it? And I need suspension lol
Idk, are their mods that are made for the 3.0s to give it some more kick than stock? Cam? Can they handle boost decently? If they can then why not twin turbo it?
