Need some info on cluster
I'm trying to find a sr5 cluster to put into my 93 p/up. The question is do any of them have the gear indicator for an auto trans? I've searched and can't find an answer. thanks
OK I'll try again. I currently have a 93 p/up 2wd extra cab. It's v6 auto. The cluster in there now has the temp, speedo w/gear indicator on it, and the fuel gauge. I want to know if there is a stock cluster out there that has a tach and the gear indicator on it? If not I wanted to know if the I can just swap out the speedo part into the cluster with the tach. The reason for all of this is cause I want a cluster with a tach and gear indicator. Hope this helps.
I suppose it's possible, but you're talking about a rare option on an already rare truck. Don't see that many 2WDs, much less autos. It may exist, but I've never seen it.
Well, sorry to dredge this up from the dead, but damned if I haven't seen the exact beast you were wondering about!
Admittedly, the truck was a 4 banger, but it was a 2WD auto with column shift, and it had a cluster with a tach, and the PRND2L lights across the bottom of the tach.
So they do exist. That's half the battle, right?
TheBFA
02-15-2020 06:55 AM
buckz6319
08-05-2017 03:50 AM
