Need some info for BIG 3 upgrade
Old 11-12-2020, 02:05 PM
RAD4Runner's Avatar
Originally Posted by OldBlueMidnight
... my advice would be to not modify the stock wiring at all,
THIS^^^
Best upgrade is to inspect, clean wiring to bare, shiny metal, coat with dielectric grease and tighten.
L and S wire do not carry load. They are merely "Information" wires. IG carries minimal current to "excite" the alternator windings.
just run a new wire from bat to alt with a maxi fuse, and make sure you test rev it as high as you plan to when driving.
Leaving stock "B" wire and adding "upsized" wire this way will bypass many of the stock fuses/FL's and not be safe (below).
Redeth, Chefyota4x4 and I deleted the stock "B" wire and ran "upgrade" B wire from alt, to proper fuse to battery.
Stock 80-amp FL continues to protect circuit, like always.
Alt and Batt work directly had in hand.
It's on my posts
The following users liked this post:
BigBluePile (11-12-2020)
wrenchtech
12-06-2016 09:22 PM
jbeezy22
05-01-2013 08:42 PM
LK1
17
09-11-2011 04:42 PM
Howdy
04-22-2009 04:01 PM
Quick Reply: Need some info for BIG 3 upgrade
