need to know if it will work
so i was figuring out what lift kit i want to put on my 4runner for 33x12.50x17
the thing is i have a 2WD 6V 3.0L 92 4runner ( Automatic tranny)
so out of these which will work
tuff country- http://www.suspensionconnection.com/548023.html
Performance accesories 3" BL- http://www.jcwhitney.com/perf-access...2166y1992g12j1
OME lift kit- http://toyteclifts.3dcartstores.com/...ner_p_224.html
which would be the best to get enough clearance for 33x12.5 BFGoodrich A/T
REMEMBER I HAVE A 2WD AUTOMATIC
Www.4crawler.com
Ball joint spacers are $80 a pair and can set your front end high enough to accommodate 33s without maxing your torsion bars to the stops.
I don't know much about 4Runner rear suspension so you'll need another Runner guy to help you there.
if you already know you want BFG AT's in 33" size - do you already have 17" wheels? If not, my suggestion would be to skip buying 17" wheels and a lift kit, then simply buy some 33x10.5-15 BFG ATs on your stock wheels and then just get a sledge hammer to massage the pinch weld in the wheel well of your rig - done. spend the rest of the money on something else.
ashersullivan88yota
01-18-2022 05:37 PM
09-04-2015 09:27 AM
crashburnoveride
07-10-2015 06:39 AM
madxman21
07-09-2015 10:26 AM
