Need Help..3.0
Old 11-25-2008, 04:52 AM
Cyberman's Avatar
Originally Posted by wii_tarded
Just a shot in the dark, is your hazard lights plug installed and connected, does it work?
Tore my dash apart this weekend and had no blinkers untill I took the flasher plug and connected it.
Ya, the whole turn signal/hazard circuit goes through the hazard switch. I think your speedo question has been answered too.
Old 11-25-2008, 05:25 AM
YoterUp's Avatar
Ok il check the hazard switch! thanks you! The only part i have left on the spedo thing is How can i adapt it from electrical to mechanical?
Old 11-25-2008, 05:38 AM
ScottyC's Avatar
You need Marlin's VSS adpater
http://www.marlincrawler.com/htm/tra...e/tcase_ac.htm
Old 11-26-2008, 09:12 PM
YoterUp's Avatar
Mabe im missing something but i have the oppisite.. i have to go from electrical to manual! the adapter on marlin is mechanical to electrical, i have a mechanical wire run down then a electrical plug in on the tcase.. any ideas on that one?
Old 11-26-2008, 09:57 PM
  #25
Bigblock's Avatar
Will the manual part fit in the elec part hole?Worth a try.
Bigblock
Old 11-27-2008, 05:51 AM
  #26
YoterUp's Avatar
ya know i thought of that but i didnt even check i figured it wasnt going to be that simple. ill look at that, anyone know if thats going to work or if im about to waste my time?
