Near Overheating
Near Overheating
Over the summer I installed a reman'd 22RE into my 89 pickup. Since then, I have had trouble with my truck coming close to overheating. What I mean is that when I begin to drive it heats up almost to where it is overheating but then goes down. I replaced the thermostat and the gasket, have put RTV Sealant on the housing because I had metal on metal and had a leak. Can anybody offer me any advice?
1 Post
did you blead all the air out of the cooling system? and or did you check the cooling lines are they hot cause the temp gauge in the dash sometimes goes south and works half the time so just make sure that it is deff overheating other then that im not sure of anything else as of this point in time hope it helps
- http://www.4crawler.com/4x4/CheapTri...tml#Thermostat
See the web page section below for a possible answer:
LotOMiles
09-14-2015 11:45 PM
