My Very Used Runner
#43
got the upper axle truss welded on, the large diff armor and knuckle ball gussets have been tacked. using the welder at work it rules
pics to come later, cause my cell broke and that's my only camera right now
#47
#49
Your truck is badass dude Pretty much what i have in mind for mine couple questions....Whered you get that soft top and when you do the 63"chevy springs what do you do about the mounts weld in new ones?
#50
the soft top i got used for a steal at $200....it has seen better days,i've had to sew some seams and put in a few pacthes...the chevys you can buy the kit that sky's off road design makes...
#52
so i dove intot the 3rd member today and found some strange things...1st off the ring gear had 37 teeth, and the pinion 9, whichs makes it 4:11s,odd knowing mostly all toyotas came with 4:10s...secondly it had a solid spacer not a crush sleeve. i didn't think toyota had solid spacers stock. also there was bearly ANY wear on any parts in the 3rd, as if 4wd was bearly ever used. and come to think of it when i 1st disasmebled the axle i remember there being a stock toyota 3rd gasket. any input
#53
im dropping my 1st gen off tomorrow, pick it up in a few months sound good? cool...lol
runner looks great, i have a lot of similar plans, and i plan on using a lot of the pictures and information you posted up to help with mine. thanks! and good luck on the SAS, i was quote 3k to have mine done, id do it myself, but i cant weld...hoping that if i put together and rebuild the SFA they will come down on the price.
#55
#56
i don't know what year your third is, but when i rebuilt one for my rear end i used one from an earlier truck(81 i think, it had 3.90s) and it had a factory solid spacer, cast iron lookin' thing.
i think crush sleeves came out later sometime?
#58
i've seen a few others before, and i think they were all first gen trucks.
good thing you got one, i think crush sleeves are kind of a pain, especially if you muck one up.
what ratio did you say you were gonna run?
#59
front: 5:29s open(for now)
rear: v6 case, 5:29s, detoirt(gonna get a solid spacer)
the front is eventualy gonna get a v6 e-locker
