My dash is falling apart.
The piece around the steering column busted loose so I've taken it off and then this morning I was leaving my apatment and I ran over the abusive speedbump at my apartment and the piece on the top drivers side busted into 3 poeces and fell right off. I might start building stuff out of sheet metal to replace it.
if I get one from a junkyard it will be old like mine was. I'm thinking about building it all out of metal. BUt you guys are probably right. I'll start checking around. It would be a lot less time consuming to put another old one on.
Screw those speed bumps. I shouldn't have to be assulted everytime I come or go from home. I'm rebelling against them.
If you "rebel" against the speed bumps, just take the column surround off. for that matter, just scrap all the plastic in your truck as its all going to rattle and break loose.
there isnt a piece of plastic dash left in my truck that isnt cracked in one or 2 places. in this case, the dash plastic stuffers over time. age makes it brittle. so virtually all junk yard dash pieces have the same issues.
trust me ive looked...
TheBFA
02-15-2020 06:55 AM
hiluxinargentina
09-30-2015 11:12 PM
hiluxinargentina
09-30-2015 05:51 PM
FS[PacNorWest]: 1987 4Runner SAS, 22RE, 5Spd, Dual Cases, etc
toyotasaurus
09-24-2015 03:30 PM
