My 88 keeps killing fuel pumps!?!?
Ok so I cannot for the life of me figure this out in the last 3 months my 88 with a 22re has killed 3 fuel pumps. Does anyone have any ideas of why this would be happening you put one in it runs great then after about a month it just goes I've put in 2 napa one and one new Toyota pump.
Just curious are you the type that runs around with the fuel tank level around 1/8 to empty all the time.
I have a few Toyota vehicles that very seldom if ever I let the tank go much below half..
I never had any issues with pumps.
Just what kind of failures ??
If they all failed within that short period most fuel pumps are warrantied for a year.
Interesting
Interesting
I hope you've been replacing the filter sock too... fuel pump warranties are usually void if you don't replace the sock... also if the high pressure filter isn't replaced, it too can cause problems
Check voltage at the pump. If low, that could cause problems. Should be close to same as at battery posts, I think.
Do you use any fuel additives?
Are you sure your fuel pumps are actually bad, and not some other problem like bad pressure regulator, circuit opening relay, fuel pump switch in air meter, or wiring?
Thanks sb I'll check into these well actually my g/fs brother bought the truck from me so I'll pass the info on I just replaced it 2 times first one lasted 8 months 2nd one died a few weeks later so then he replaced the napa one I used with a Toyota one and it died on him two weeks later so thanks everyone for the help
is the COR bypassed? is the pump staying on all the time? any kinks in the hardlines? Is the vehicle running rich or lean? Pumps rarely go out by them selves. Something is causing them to fail. I know that clogged fuel filters are usually the biggest culprit. Pull the filter and try blowing through it in the direction it should flow. Is it easy to blow or no? When you pull the failed pumps, can you hot wire them and get them spinning by tapping on them? maybe they suck in debris? Maybe your charcoal canister is failing and sending its guts to the tank? Good luck!
I have this same problem!!
Vance! What ever happened with this vehicle? I have the same issue with my mini cooper and the last mechanic just gave up on it! Only problem is mine is actually worse! My car only lasts a day or two before killing the fuel pump and I've been through 5!! I am hoping you can shed some light!!
TURBOrunnerNM
07-22-2015 11:01 AM
