more 3.4l swap ?
more 3.4l swap ?
so i spent countless days searching here and every other site i could imagine looking for some info on the 3.4 swap and still have a few questions that i need answered. i have a 89 pickup 22re. i picked up a 98 3.4 from a 2 wheel drive auto runner i got all accesories and complete harness including cowl harness. i have tranny,tcase,driveline,crossmember,oil pan, pickup,dip stick and tube, throwout,radiator from a 89 v6 ext cab truck. i need a computer,flywheel, clutch, starter,exhaust. im going with a ors harness, downey headers, and picking up a 3.4 flywheel from the bone yard. i think i got everything covered so here is my questions the computer i need one from a manual trans but does it have to be 4x4 or can i use one from a 2 wheel drive? which starter do i need 3.0 or 3.4 starter? i have one from the 3.4 auto trans but i dont think it will work. i know i need to move motor/crossmember mounts but thats easy. so any help or advice would be great. btw great site
i know the computers are different i need a manual transmision computer but does it have to be 4x4 or can i use a 2 wheel drive manual transmision computer?
You can use the 3.4L starter. I have no idea if the AT starter is the same as the MT starter but a simple part number search would tell you that. If you want an easier exhaust install I would use the custom ORS crossover. I used Downey headers on my swap but this was before the crossover was available.
Seattle_Sign_Guy
07-12-2015 12:38 PM
