Old 03-11-2016, 03:28 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Tire Repair and Maintenance
Print Wikipost
Maximum tire size without a lift?
Old 12-22-2008 | 08:58 PM
  #41
sa51's Avatar
Originally Posted by My99
Thanks fellas. In reading a few other threads, it appears narrow is better.
no problem narrow is def better if you want tall tires with minimal or no lift
Old 12-22-2008 | 10:09 PM
  #42
gary96360's Avatar
Originally Posted by 87pu
the reason u got more power is a 365/75r16 is smaller then a 31" tire it is actually a 30 in just in case u didnt know that already
um 265/75r16 is a 31.6 inch tire check it out on this site
http://www.miata.net/garage/tirecalc.html
Old 12-22-2008 | 10:35 PM
  #43
abecedarian's Avatar
I was going to say something about that too since my 265/75r16's are over 31" tall... but decided against it.
Old 12-23-2008 | 12:39 AM
  #44
91 4Runner's Avatar
Originally Posted by tc
- you have not installed an auxilliary tranny cooler
I will attest to this statement. I'm on my second used tranny, and there was a new tranny in my Runner when I bought it. 2 trannys I beat the ever livin crap out of, but the first tranny my wife just drove daily to work - about 14km for 14-16 days per month with 32x11.5 at's. After that I installed an afterrmarket tranny cooler - second largest you can get inline with the factory. I will tell yo 4.10's and 33x12.5's is hard on the tranny - I wish I could have used the tranny money for gears. I would have gone 5.71's just to have the extra umph.....
Old 12-23-2008 | 02:51 AM
  #45
Alex 400's Avatar
Originally Posted by yotaman90
I've never had a need to install a tranny cooler. Would my transmission really heat up that much?
do you have a temp gauge on the trans? How do you know you didn't? If you don't know how hot the transmission is getting over periods of time, then you really can't judge if you need one. Once the transmission gets hot, it takes a while, without stopping, for it to cool. When we installed the trans temp gauge on my dad's f-250, we put the probe before any cooling took place, so that the gauge read the true temperature of the tranny fluid coming out of the the transmission before the coolers. REason for this: if your transmission is 250+ degrees (too hot anyway) after the cooler has taken off 50 degrees, the transmission is really running at 300 degrees, which will kill tranny fluid and clutches very quickly. I think any automatic transmission vehicle that you either, go over the pass with, tow with, wheel, modify, etc., at minimum needs a tranny temp gauge, if not an auxiliary cooler.
The automatics have a really high 4 gear, as you probably know, it shifts a lot between 4th and 3rd because the engine doesn't have enough power to hold it in 4th. You need to get at least 5.29's for your 31" tires for good power and 5.71's for anything higher.
djpg2000
11-11-2020 04:56 AM
jgallo1
10-26-2015 06:39 PM
justdifferentials
Just Differentials
08-15-2015 05:25 PM
coffey50
07-28-2015 10:55 AM
Gravel Maker
RuffStuff
07-27-2015 06:53 PM
Quick Reply: Maximum tire size without a lift?
