manual hubs question
#30
I got ADHD. Manual hubs will bolt right on there. Lotsa folks do it, and then disable the ADD actuator and lock it in the "engaged" position. Setting you up as a manual hub truck.
#32
What do you mean this sucks? Converting from ADD is FAR easier than from auto hubs. You literally just remove the diff flange and the put the aisin on there. If you go to wabfab and look at the items that are included you will see how little effort is required to switch them
#38
Ok, here's the process:
Park vehicle, lift vehicle, support it on jackstands that aren't pieces of lumber in a sketchy Jenga looking setup
Remove wheel
Remove Drive flange, or hub plate, or hub flange, or drive plate, or whatever else it's been called here
by removing the gold cover thingy with a hammer and flat head screwdriver. Just tap it, no need to pretend it's your boss at work or anything
There may or may not be a 12mm head bolt with a large washer on it threaded into the end of the axle, remove if there is. Then remove the snap ring(hopefully you have snap ring pliers for this, it's a pain with anything else)
Sorry, no picture of that handy. After removing the 6 12mm nuts and washers around the drive flange, use a brass drift punch and hammer to tap on the ends of the studs you just removed said nuts and washers from, like so
This is to remove these
Then pull the drive flange off. If it really doesn't want to come off, even with the cone washers removed, thread a couple of the appropriate size bolts into the 2 threaded bolt holes towards the outside of the drive flange, and evenly tighten them down to slide the flange off the studs and dowels
Find these
Although, probably black, red, and silver, not painted like mine
Remove 6 bolts around the outside of the dial face(red and plack part, normally) with a 10 mm socket
Pull dial face out of hub body
There may or may not be a bolt in the end of the axle again, remove a snap ring again, then remove 6 12mm nuts and washers and repeat brass drift punch and hammer technique
Remove hub body(probably silver, not hammered black)
Install hub body onto your vehicle, after checking the wheel bearings and tightness of the 54 mm nuts holding them on the spindle, put in cone washers, lock washers, tighten 12 mm nuts, put back snap ring and bolt in end of axle(if there), install dial face into hub body. If dial face will not seat all the way, remove and clock it a slot to the right. If it still won't, repeat clocking a slot to the right. If it still won't, we'll need to see pictures of what's wrong. If it does go all the way, tighten 10 mm bolts and enjoy your manual locking hubs.
Remove wheel
Find these
