Old 03-11-2016, 03:20 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Engine Problems by Symptom
Print Wikipost
Major loss of power, truck wont go faster than 30mph
Old 12-04-2014 | 01:38 PM
RJR's Avatar
RJR
Jenny alluded to this earlier, but you need to get into the cabin, pull off the right kick panel and find the ECU. Put a multimeter from ground to pin 11 (VTA) of the ECU. With the ignition on but the engine not running, slowly move the accelerator from idle to full open and watch the meter. The voltage should go smoothly from 0 to 5 volts. If it doesn't, you have faulty wiring between the TPS and the ECU, or a faulty TPS. My guess is that you'll see the voltage stuck close to ground.
If either the VCC wire or the ground wire is open between the TPS and the ECU, the TPS signal will be stuck at Gnd or +5V, respectively. If this happens the ECU will be totally confused about what's going on. When you pull the TPS plug off, the TPS signal is pulled to about +2.5 volts by resistors internal to the ECU, allowing the engine to run reasonably, if not optimally.
If the voltage is correct but the engine won't run with the TPS connected, it's possible the ECU is the problem. They rarely fail, but this could be one of those times.
Old 12-04-2014 | 03:25 PM
924runner17's Avatar
Im not too good with electrical, so is there a blown out diagram of the terminals? The ECU is almost brand new so im thinking that isnt the problem but i will indeed check.
Old 12-04-2014 | 06:28 PM
RJR's Avatar
RJR
Here's a pinout for a '95. Yours should be similar, I would think. Terminal VTA is the output of the TPS. Terminal E1 is ground.
Attached Thumbnails Major loss of power, truck wont go faster than 30mph-95-3vze-ecm-pinout.jpg
zd92655
03-06-2022 12:58 PM
bigblue82
10
07-06-2015 08:27 AM
be_deviler
07-01-2002 05:27 PM
HALMAN
06-24-2002 06:01 AM
Dr. Evil
06-07-2002 09:19 AM
Quick Reply: Major loss of power, truck wont go faster than 30mph
