LSPV lift bracket
Old 08-21-2008, 09:53 AM
tman12345's Avatar
LSPV lift bracket
I'm doing the cruiser coil lift so should i order the LSPV bracket for 3 inch or 4 inch?
Old 08-21-2008, 10:01 AM
abecedarian's Avatar
I'm cheap. When I put the lift on my runner, I got some of the perforated steel from Home Depot, cut it into 6" pieces which I stacked three together then cut it to look like this:
cost me about 5 bucks including gas to the depot and is adjustable.
Old 08-21-2008, 10:03 AM
904_runner's Avatar
it depends, the cruiser coils off an 93 gave me about 3.5 inchs of lift , i think. I didn't even put one on mine.
Old 08-21-2008, 10:26 AM
dirtoyboy's Avatar
x2....dont spend any more than you have to...just head on down to Homo depot
Old 08-21-2008, 04:57 PM
tman12345's Avatar
any pictures with a bracket on?
Old 08-21-2008, 05:16 PM
Old 08-21-2008, 05:52 PM
Jay351's Avatar
You'd be amazed at the loss of breaking power with only 1" of lift. I would rig one up..
Old 08-21-2008, 07:27 PM
tman12345's Avatar
is this basically the same bracket i need to make? This is a 1st gen 4runner right? Is the LSPV in the same spot?
Old 08-21-2008, 07:41 PM
this is a 1st gen runner. the bracket is the same as my 91 truck (same as 2nd gen runner, save for the coil springs)
Old 08-21-2008, 07:47 PM
drew303's Avatar
its in the same spot on all models.
Get or make a 4" bracket. More is better than less. You can always adjust it on the arm itself.
Old 01-26-2009, 12:12 PM
SMOD's Avatar
Say the lift gave 3.5" Would it make a difference if the bracket was 4" ?
Old 01-26-2009, 12:24 PM
904_runner's Avatar
Okay i finally ended up bungy cording mine up for now. Yes it absolutely stops better.
qdude79's Avatar
My '90 was/is located in the same location. I'd go with the 4". I sized mine to my exact lift, and I don't think it was enough. I'd go over.
Old 01-26-2009, 12:29 PM
Matt16's Avatar
Not only stopping power, I noticed that the truck stopped pitching forward when stopping. Felt more driveable.
Jay, when did you put your LSPV bracket on?
Old 01-26-2009, 12:49 PM
SMOD's Avatar
Thanks..
I think I'm going to get a little piece of metal at B&C and drill holes in it.. or find a piece that has holes already drilled.
Old 01-26-2009, 03:44 PM
SMOD's Avatar
Gosh, that piece is so common and I would think that even my little hardware store where I live would at least have a piece of metal that would work for the ispv but they don't. The closest thing would be a door hinge that they have.
Ugh.. that's what happens when you live in a small town. lol.
I'm probably going to get one fabbed at a local metal fab shop. Or just have them give me some scrap pieces of metal.
Old 01-26-2009, 04:00 PM
LTrunner's Avatar
i just zip tied mine up to the underbody...stops great and never had any problems, been driving like that for 2 yrs now
Old 01-26-2009, 04:03 PM
86Toyrunna's Avatar
haha ^ x2... got sick of it so i ened up just cutting the arm off it and zip tied it up.. really helps the 35s stop
Old 01-26-2009, 04:13 PM
SMOD's Avatar
Do either of you have a pic with the zip ties?
Old 01-26-2009, 05:09 PM
904_runner's Avatar
simple, find something under the truck, take a zip tie or bungee cord and hang it up there
Quick Reply: LSPV lift bracket
