Lower Ball Joint
Order the Beck Arnley ones on amazon. Like 30 or so a piece. I just ordered some a couple weeks ago and inside the box were Sankei (555) joints. Basically short of Toyota, I think its as good as you can get. Also, they are grease able.
The Moog upper & lower ball joints I bought at Rockauto are also stamped 555 & say "Made In Japan" They come with grease fittings in the bag but as the sit in the sealed plastic bag there is a bolt in that spot just like the OEM ball joints are on the truck.
D'oh...double post. I didn't see a way to delete the first one.
Greasable are the best bet, and if they come with a bolt in place of the zerk fitting, that's just so you can remove the zerk after greasing. Put the zerk in, grease, pull the zerk and replace with the bolt- then nothing to break off on the trails.
Odin
09-24-2015 05:38 AM
JRB4Runner2015
09-20-2015 01:29 AM
