Old 03-11-2016, 03:21 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Engine Problems by Symptom
Print Wikipost
Low/Rough idle after warm start? 22RE
Old 11-22-2014 | 08:31 AM
  #61
ra33it's Avatar
Amazing!
Old 11-22-2014 | 05:24 PM
  #62
skebe22RTE's Avatar
Originally Posted by jennygirl
Hey guys just resurrecting this thread, I've been chasing this problem for months myself.
It all seemed to start around the time I did the battery/intake swap.
Symptoms:
-starts up fine cold
-runs great on the road
-after engine off and heat soak, engine idles low and rough until you get going
Check to see if your intake air temp (IAT) sensor is getting heat soaked by the AFM housing.
Short version:
Try pouring ice water on the AFM when it's doing the crappy low startup idle and see what happens....
Long version:
  1. Stick a multimeter in ECU's THA terminal to read intake air temp voltage at the ECU.
  2. Go drive around and get the engine nice and hot like normal, write down voltage during throttle open.
  3. Turn the car off and keep ignition on
  4. Notice the voltage drop (lower voltage = hotter sensor)
  5. Turn the ign off & wait 10-20min
  6. Turn ign on and take note of the voltage, it has probably dropped a ton (heat soaked IAT sensor condition)
  7. Try starting the car, crap idle like usual.
  8. Pour icewater on AFM (careful not to get any in your air filter if you have a K&N style) until multimeter reads a similar voltage to the one you recorded earlier
  9. Start back up... Vroom?
I'm also getting CEL lights cruising on the highway, O2 lean. I can clear the CEL by blipping the throttle.. which would make sense because that would un-heatsoak the IAT for a brief moment.
What I want to do now is remove the IAT from the AFM and relocate it somewhere shielded/insulated where it won't get soaked, like right behind the filter in my intake tube before the AFM. Or maybe I could just move the whole AFM itself or shield it really well. Anyone know how hard it would be to find a matching temp sensor that I could mount externally from the AFM? I imagine pretty hard. Luckily I have a spare AFM I can try to rip it out of....
Let me know if you guys have success with this diagnosis procedure. I've been able to reproduce it about 3 times in a row shouting "hallelujah" at the top of my lungs each time as I hear the engine start to run buttery smooth... doing nothing but pouring some dang icewater on the stupid AFM. My IAT is getting super heat soaked, problem solved. I am sure of it. Now I am wondering if y'all are having the exact same issue...
greetings jennygirl, i really appreciate you sharing your feed back! seems like no one want's to write back these days if they've found the problem and you can tell these people figured out the problem because they don't mention it ever again... any ways, but of course ever since i wrote on this post, i haven't solved the problem yet. i do know its got to be a fuel problem because it feels like it's running rich and you could kind of smell the unburnt fuel... so i will try this when i have a chance and let you know for sure! give me some time though because i hardly drive my truck and next time i'll get a chance to look at it may even be within the week or so...
Old 11-22-2014 | 05:34 PM
  #63
muddmadness's Avatar
I still have the issue I will try the ice water
Old 11-22-2014 | 09:47 PM
  #64
jennygirl's Avatar
Rabbit did you try it with success?? Iwill be so excited to hear if someone else can reproduce this.
Skebe- firstly I'm happy to hear your appreciation. Thank you kind sir I'm also looking forward to your results as well as Mudd.
Have any of you done the battery intake swap?
Old 11-22-2014 | 09:59 PM
  #65
Not yet but totally thinking about it mine is such a pain where it is
Old 11-22-2014 | 10:37 PM
  #66
jennygirl's Avatar
I hear you. Yeah that stock air tube does get in the way.
If you do, be sure to mount the AFM as far away from the TB and sources of engine heat as possible. It's very likely that doing the battery intake swap ibcreases risk of IAT heatsoak by a large margin
Old 11-23-2014 | 07:10 AM
  #67
Sounds about right, I am just tired of my fan blade getting shaved because there is no way to mount it properly where its at.
Old 11-25-2014 | 05:29 PM
  #68
RJR's Avatar
RJR
Anyone know how hard it would be to find a matching temp sensor that I could mount externally from the AFM? I imagine pretty hard. ..
Shouldn't be too hard. It's just a thermistor that measures about 2.5K at 25degC. Just go to DigiKey and you can find a bunch that will probably work.
Old 11-25-2014 | 08:15 PM
  #69
jennygirl's Avatar
Thanks RJR, this one seems like it will work?
http://www.digikey.com/product-detai...014-ND/1014542
I guess it's probably a better option- rather than sacrificing an entire AFM for such a simple component.
Old 11-25-2014 | 08:20 PM
  #70
RJR's Avatar
RJR
Looks to me like it would. Doesn't cost a lot to find out - they're pretty cheap. Shipping will cost more than the part, unfortunately.
Old 11-25-2014 | 08:47 PM
  #71
jennygirl's Avatar
Basically what I wanna do
Cold air intake extension and mount the temp sensor as far from the TB as possible
Low/Rough idle after warm start? 22RE-qtqtxi6.png
Old 11-25-2014 | 08:53 PM
  #72
Let us know if it is successful or not. Hope it works, good luck.
Old 11-25-2014 | 08:55 PM
  #73
I'm just wondering where to put the xtra extended hose short on room.
Old 11-25-2014 | 08:56 PM
  #74
jennygirl's Avatar
Wow you weren't kidding. Shipping is about 6-8x the price of the thing.
I think I'll be taking apart my spare AFM instead...
Old 11-25-2014 | 08:59 PM
  #75
Bummer had to send mine in for the core charge.
Old 11-25-2014 | 09:03 PM
  #76
jennygirl's Avatar
Have to check it tmrw, but I am thinking I will try to make a hole in the sidewall to route the pipe into the area behind the fender / in front of the wheel well. Should also bring in colder air and give me +50hp
Well I'm hoping it's easy enough (and providing this DOES work) that one could take the IAT out of the existing AFM and simply re position it- which would mean zero extra parts besides the extra tubing
Old 11-25-2014 | 10:35 PM
  #77
jennygirl's Avatar
Low/Rough idle after warm start? 22RE-o09fao1.png
http://www.bosch-motorsport.de/media...2650379pdf.pdf
Readily available, autozone and oreilly even have it
I just checked cold air routing options, and I guess I didn't realize how little space there is in that area. I'm going to keep the filter and piping as is and try to mount the air temp sensor in the end cap of the filter itself.
Definitely using that bosch unit
Old 11-25-2014 | 11:04 PM
  #78
jennygirl's Avatar
Could not be a more perfect match
Low/Rough idle after warm start? 22RE-y9xubfq.jpg
I plan to mount it here, in the end of the filter
Low/Rough idle after warm start? 22RE-whlfmhr.png
Old 11-26-2014 | 05:55 AM
  #79
RJR's Avatar
RJR
Looks perfect. Good find!
Old 11-26-2014 | 05:56 AM
  #80
rworegon's Avatar
Looks promising!
Quick Reply: Low/Rough idle after warm start? 22RE
