Loud knocking at start up, goes away and starts again at higher rpm
My truck is knocking very badly at start up. After I give it a couple revs it’s mostly goes away, but returns at astound 2400 rpm. I played with the distributed and a timing light and it’s gets close to 5 btdc but with the distributer all the way retarded. Is the engine not timed correctly?
When I jump the wire I don’t get a drop in revs, but, I do get a check engine light. I will move on to the tps. Would the tps cause the knocking or just the timing issue?
Harold Of The Rocks
08-03-2019 04:31 PM
Chrisz
03-18-2018 04:37 PM
