Looking for a spare tire holder
I might just have to get on this with my next paycheck.
I looked at them, & not bad. What would you'll go with, the 12 ton or 16 ton? Im kinda looking at the 16 ton air/hydraulic pipe bender for $219...
#25
12 ton is sufficient for what you need - I have a 16 ton model with mandrels up to 4" diameter - I got that for free helping a bud with a trans rebuild - otherwise I would have gone with the 12 ton
#27
I've build many bumpers with my Bender and one trick I found with the Harbor freight "Kinker", use the mandrel that is .250 inches smaller than the OD of the tube you are bending (ie the 1.25 mandrel for 1.5 OD DOM tube) .. I can do all most 90 degrees with mine.. Good luck..
#28
I could not find exactly what I wanted either, so I compromises on something that I could do now and leave it till later.
I put a MC rear bumper on my rig. It has a receiver hitch on it. I then bought a swing down tire carrier that will plug into the receiver. The tire carrier will hold a high lift jack and the license plate. When I don't need the tire carrier, I leave it in the garage.
The tire carrier is by CBI.
#29
really dont know how you guys are using these kinkers , i could not make any good bends with the manual hydraulic one ,had to buy a real one .
i tried the packed wet sand in the tube trick and no go.
dropzone
08-11-2015 05:16 PM
mr_manny
07-31-2015 10:39 AM
skoti89
07-08-2015 12:05 AM
