Looking for an 88-92 3vze distributor plug wire diagram
in the plug of the 88-92 of the 3vze what is each of the wires? which one is ground and signal, hot, etc. I have the 93-95 wire diagram, just need the 88-92. trying to help a friend out. I cant seem to find it on bing or google.
im trying to test a 90 3vze distributor per the fsm. I have the 93 fsm test for the distributor. the 93-95 distributor plug is different than the 88-92 plug. im trying to figure out what wires to test. in what order etc etc.
the 93-95 plug is a single row of 4 wires
the 88-92 plug is a double row of 2 wires.
hence my confusion
hence my confusion
Yes I am. They FSM I have covers the 93-95 distributors. The wire colors do not match up or the plug configuration. I'm am looking for the correct testing procedure and wire color designation
Found it...Is this what you want?http://DSCN0022.JPG
https://www.yotatech.com/forums/f116...e-12-a-274839/
I was trying to help this guy out. I then realized that I didn't have the correct information for his truck. thanks for the info
try this...looking at the dist plug up left G1...up rt NE.....Low left G2...Low rt G neg
Test...G to G neg...205 to 255 ohm
test...G2 to G neg...205 to 255 ohm
test...NE to G neg...205 to 255 ohm
if not, replace dist housing.. hope this helps
I believe you may be wrong there. From what I've gathered the wire colors should be as follows.
NE
G1
G-
G2
BTW, bc...I answered this question in a previous thread that you were also involved in.
https://www.yotatech.com/forums/f116.../#post52042937
EDIT: All posts will be corrected for total accuracy. Sorry for the confusion.
NE
G1
G-
G2
