locker question
locker and tires
The detroits or spools mite work better than mine on ice with differnt tires. Swampers and lockers with ice on the roads means im not driveing it
I think If your gonna DD on a rear locker you need to know how to drive and leave your swampers in the garage.
#31
diff decoder
Since I'm considered the forum idiot, here's where I got the info,......Hope this helps:
Read the Axle Code from the vehicle indentification plate.
first digit: ring gear diameter
A 138mm
B 145mm
C 6.25"
D 6.62"
E 7.1"
F 7.5"
G 8"
H 9"
J 9.25"
K 9.5"
L 10.5"
M 12.5"
N 13.5"
P 14"
Q 12"
R 162mm
S 6.38"
T 6.7"
U 6"
V 10.6"
W 15.5"
X 142mm
Y 158mm
Z 202mm
- no ring gear = FWD
Second, third digits: gear ratio
01 3.30
02 3.36
03 3.545
04 3.556
05 3.70
06 3.889
07 3.90
08 4.111
09 4.222
10 4.375
11 4.444
12 4.625
13 4.79
14 4.875
15 5.125
16 5.286
17 5.60
18 5.714
19 5.833
20 6.167
21 6.667
22 6.78
23 6.833
24 7.64
25 4.556
26 5.571
27 3.364
28 4.30
29 4.10
30 3.727
31 3.909
32 6.591 or 4.807
33 7.503 or 5.583
34 6.781 or 4.786
35 7.636 or 5.60
36 4.778
37 3.583
38 3.417
39 3.154
40 5.375
41 3.308
42 6.500
43 3.550
44 3.214
45 3.533
46 2.928
47 3.944
48 3.356
49 3.729
50 3.400
51 3.736
52 3.722
53 3.250
54 3.941
55 3.333
56 2.821
57 4.058
58 3.238
59 3.234
60 3.519
61 2.724
62 2.892
63 2.655
64 4.312
65 3.837
66 3.071
67 3.526
68 3.095
69 4.176
70 5.857
71 2.962
72 3.949
73 4.285
Fourth digit: no of pinions, ltd slip-yes/no
Code pinions ls
2 2 no
3 2 yes
4 4 no
5 4 yes
http://forums.toymods.org.au/index.p...t=0#msg_311760
http://www.toyodiy.com/parts/q.html
A 138mm
B 145mm
C 6.25"
D 6.62"
E 7.1"
F 7.5"
G 8"
H 9"
J 9.25"
K 9.5"
L 10.5"
M 12.5"
N 13.5"
P 14"
Q 12"
R 162mm
S 6.38"
T 6.7"
U 6"
V 10.6"
W 15.5"
X 142mm
Y 158mm
Z 202mm
01 3.30
02 3.36
03 3.545
04 3.556
05 3.70
06 3.889
07 3.90
08 4.111
09 4.222
10 4.375
11 4.444
12 4.625
13 4.79
14 4.875
15 5.125
16 5.286
17 5.60
18 5.714
19 5.833
20 6.167
21 6.667
22 6.78
23 6.833
24 7.64
25 4.556
26 5.571
27 3.364
28 4.30
29 4.10
30 3.727
31 3.909
32 6.591 or 4.807
33 7.503 or 5.583
34 6.781 or 4.786
35 7.636 or 5.60
36 4.778
37 3.583
38 3.417
39 3.154
40 5.375
41 3.308
42 6.500
43 3.550
44 3.214
45 3.533
46 2.928
47 3.944
48 3.356
49 3.729
50 3.400
51 3.736
52 3.722
53 3.250
54 3.941
55 3.333
56 2.821
57 4.058
58 3.238
59 3.234
60 3.519
61 2.724
62 2.892
63 2.655
64 4.312
65 3.837
66 3.071
67 3.526
68 3.095
69 4.176
70 5.857
71 2.962
72 3.949
73 4.285
Code pinions ls
2 2 no
3 2 yes
4 4 no
5 4 yes
#32
it will eat tires if u give it gas the whole time around the corner. i dont think it will eat tires bad if u left off the gas around the corner then give a tiny bit gas at the apex
#33
kinda a thread jack, but IF you had a full floater kit and a locker or welded/spooled rear dif then could you run one of the rear hubs unlocked?? or will it hurt thr gears at all??
i mean, in theory, it would trick the truck into thinking that the rear is spinning all the time, right??
#35
Amen to everything Dirt Master80 and plumbrbob said. A selectable is great but pricey. Welded or a spool is a little rough on the tread and squeaky around corners but it is 100% predictable and reliable. ovrrdrive is the only person i have ever heard say anything good about a lunch box lockers road manners or reliability.
#36
#37
#38
#40
If you do decide to go with an auto locker then I recommend the Aussie. I run one in my pickup and it's a DD during the week and a weekend trail rig. I've had very few issues other than some snow problems but that was due to terrible traction conditions with ice and me not airing down. In fact I like the Aussie so much that I'll be running them front and rear on the new trail rig.
