Load leveling air bags
88 4runner...
I'm going to be using a hitch rack for a motorcycle and wondered if anyone has put on airbags on there rear? If so what did you use? Brand? Cost?
My motorcycle wieghs in around 230-240lbs.
thanks in advance!
sorta' like this...
thanks in advance!
sorta' like this...
I am working on a setup to install a single Firestone air bag in the center of my '85 rear axle. Putting in a center cross beam and bracket atop the axle to put the bag between. Air solenoids will be above the bag for inflation/deflation. Axle bracket will have a built in pivot to allow for axle articulation under the bag.
But for a simpler setup, see below:
- http://www.4x4wire.com/toyota/4Runne...ar_air_shocks/
If you're stock height, and driving moderate trails, air-shocks might be a better / cheaper option.
But as always, 4Crawler is thinking ahead and has a good solution without sacrificing articulation.
justdifferentials
Just Differentials
09-17-2015 06:14 PM
terminator
07-27-2015 07:13 PM
skoti89
07-08-2015 12:05 AM
