Little help with two trucks, motor problems
![hillbilly](https://www.yotatech.com/forums/images/smilies/hillbilly.gif)
well not exactly the truck didnt come with a hood well i think ill be doing away with the carb and going to efi
i think i have everything i need to do that
i have an efi intake exaust manifold fuel tank
entire wire harness from front to back
btw its out of a 4runner
turnin truck into 4runner do you know if i can use the carb fuel lines
If you're going to EFI, you'll need the entire top end. Plus, sensors, ECU, relays, fuses and panels, and I believe even fuel pump. Not sure on that, but I believe the wiring is different.
On the '90....
You can temporarily plug the EGR vacuum line with a BB or something similar to see if that changes things. Otherwise, test the engine coolant sensor on the front of the motor.
duckhead
170
11-13-2017 06:07 AM
bigblue82
10
07-06-2015 08:27 AM
Crazy_Guy97
12
06-24-2015 04:02 PM
