List of all light bulb types?
#25
Ok, here's my list, based on what I personally found. I used JDM ASTAR on Amazon for the front markers, rear turn signals, and brake lights, and superbrightleds.com for the reverse, licence plate, and flasher relay.
All are white unless otherwise specified.
Interior:
Front dome: 3175 (x2)
Front doors: 3175 (x2)
Passenger dome: 3175
Rear dome: 3710/6418?
Steering column: 74
A/C: 74
Glove box: 74
Instrument: 158 (x6, 3 white/3 green), 74 (x14, 12 white/2 green)
Exterior:
Headlights: H6054 (x2)
Front side markers: 194/T10 (x2)
Rear turn signals: 1156 (x2, amber)
Brakes: 1157 (x2, red)
Reverse: 921
License plate: 194
Flasher relay: CF13GL-02 (this is the German version, NOT Japanese, the Japanese one doesn't have the correct polarity for this application).
Interior:
Steering column: 74
A/C: 74
Glove box: 74
Exterior:
Reverse: 921
License plate: 194
The following users liked this post:
jacksonthomas (04-04-2021)
#26
I bought the CF13GL-02 flasher relay. Also led bulbs. How do you get the stock flasher un-plugged? Any tips or tricks are appreciated.
I managed to find it at left side of steering wheel by removing lower-left dash panel. Then I have to look up at it. Not much room for reaching in from behind the flasher, by working my hand behind tube for left dash vent. Also it looks like when connector is detached that stock flasher slides down out of a what appears to be a bracket. At least I was able to un-hook the hood-release and fuel filler door 'pulls' and put everything back together. Mine is 92 which might be different than a 90. Thanks.
#27
Toyota 4Runner ... First generation (1984–1989)
(1984, 1985, 1986, 1987, 1988, 1989)
High & low beam headlight H6054
Parking light 194
Front turn signal 1073
Rear turn signal 1073
Tail light 1157
Stop light 1157
License plate 194
Back up light 1073
Front sidemarker 194
Parking light 194
Tail light 1157
Stop light 1157
License plate 194
Back up light 1073
Manual (below) says 1034 for stop lights but original post above lists 1157 and that's all I can find on on Amazon and Superbright LED's website. Also, manual and original post lists 1073 for backup lights but Amazon and Superbright LED's only list 1156.
1) Has anyone confirmed that 1034 and 1157 are interchangeable
2) Are 1073 and 1156 also interchangeable?
3) Finally, there should be no error sensing when replacing stop lights and backup lights with LED, correct?
Melrose 4r (08-10-2020)
mattbatson
12
03-07-2014 07:42 PM
dbikeman
15
09-12-2003 08:16 PM
