Lift and tires for 1994 reg cab p/u
just wondering if anyone here has any ideas for a lift for a 1994 toyota p/u? i want to put 35s but i dont think the 22re can handle it well. ive searched and olnly found 4' susp. lifts, but if need i will do a body lift. money is not a realy problem so any ideas would help thanks
first off WOW money is no object !!!!!!!!!!!
as everyone will tell you. 33" tires are much easier to fit.
There are several options depending on what you wish to do with your truck.
Serious off roading??
just bigger tires???
The 22RE can handle the the 35's but you will need to regear your truck with 5.29's
let's start with cheapest way
body lift is the cheapest way to go...some people like them some don't
you can do a small suspension lift and small BL combo....
then the 4 inch suspension lifts..kinda price...
I just did the 3 inch body lift on my truck this last weekend...
still need to get my tires but the truck is lifted.
I also have a little from shackels in the rear.
after I got the body done I think I have decided against installing the BJ spacers I have.
See 4crawler.com for you lift needs...great guy...tons of great info...he wont steer you wrong.
Is it a manual? If so, 5.29 gears would be a great match for 35" tires. If you do not regear, the 22re will have big issues turning that big of a tire. If you do regear, and money is not a problem, I would highly suggest installing lockers as well, or a lsd system like the Truetrac. I really like my setup, with a 4" susp lift, and a 3" body lift. 7" of lift is great for 35" tires.
Originally Posted by tc
Money is no object + big tires = SAS
Flying91
45
04-11-2024 04:39 PM
Road Bull
10-10-2015 04:55 PM
09-04-2015 09:27 AM
