lift with stock rims?
Old 08-11-2008 | 04:54 PM
tman12345's Avatar
can you do a cruiser coil/bj spacer lift and use the stock 4runner rims?
Old 08-11-2008 | 05:03 PM
toddowaddo's Avatar
Yes. You may get some mild rubbing on the inner sidewall from the control arm though. I did on my stock 31x10.50's. The bulge of the tire gets real close to the control arm and rubs occasionally. Problem disappeared when I went to 33x10.50's.
Old 08-11-2008 | 05:06 PM
tman12345's Avatar
i forgot to mention i am gonna do 33x12.5 inch tires
Old 08-11-2008 | 05:29 PM
toddowaddo's Avatar
That's funny because I'm looking to do the same thing. I recently moved back to the N.C. coast and do alot of surf fishing. I need a less aggressive wider tire to drive on the beach. One of us needs to do a test fit
I'll go out tomorrow, get under my 4runner and do some measuring. I'll post here tomorrow what I come up with.
Old 08-11-2008 | 05:41 PM
tman12345's Avatar
that would be awesome, thanks man.
Old 08-11-2008 | 08:10 PM
Jay351's Avatar
12.50" tires are too wide with stock backspaced rims. You need rims with 4-3.75" of backspacing. Or you can grind away your upper controll arm..
Old 08-12-2008 | 07:22 AM
toddowaddo's Avatar
Jay's spot-on for the most part. Looks like I could get away with it barely because I have 1/4" spacers but I'm not going to try. You'll get some rubbing at full lock on other stuff anyways. Looks like I'll be looking for some cheap 15x8's before I buy the 12.50's.
06-01-2021 02:51 PM
chukarhunt
12-08-2019 12:39 PM
coffey50
07-28-2015 11:55 AM
Yotoder865
07-09-2015 08:51 PM
MTLroadierunner
07-06-2015 01:17 PM
