Let's discuss brake fluid in our non-ABS trucks...
I am thinking of switching to the silicone-base DOT-5, as it is the least prone to water absorption from what I read. What are the disadvantages of DOT-5 in a non-ABS brake system? I care more about longevity over the boiling-point rating since I am never hard on the brakes and our trucks are not racers!
As far as glycol-based DOT 3,4 or 5.1, which one is best for the least amount of water absorption? I read all different theories on what is best for longevity.
What are you guys using and why? Thanks
I just use DOT 3 because that is what Toyota specified for these trucks.
I really haven't thought about switching to anything other than DOT 3, so I don't know what would be best.
I did recently buy a DOT 3 specific water content meter, but I haven't tried it out yet: https://www.otctools.com/products/br...d-tester-dot-3
I am sure I am overdue to replace the fluid.
The following users liked this post:
Paul22RE (01-17-2021)
I use the dot3 for the same reason. It's what Toyota specs.
Having said that, the DOT5 silicone wasn't available thn. It's entirely possible it's a better choice. I can't say. Sounds to me like it might be, though.
Pat☺
Pat☺
Silicone based brake fluids should NEVER be used in ANY engine vacuum operated power brake system.
Most systems that call for silicone are electric, or engine driven hydraulic assist/
If the silicone fluid is aspirated into the engine, as in master cylinder cup failure; it combusts into super abrasive silicas. This equals ENGINE DEATH.
Use regular DOT 3 or DOT 4 glycol based fluids and change it out when it gets dark.
Silicone can be a good upgrade in antique and classic cars that do not have vacuum boost.
A brake system with no air in it should self bleed, just by opening a bleeder. I start by syphoning the master cylinder reservoir and mopping it clean with a lint-free cotton rag,
then fill with clean fluid and bleed every wheel 'til the fluid runs clean. Longest line to shortest. Only ONE bleeder open at a time.
I use this to bleed, works great: https://capritools.com/shop/vacuum-brake-bleeder/
Pneumatic type from Harbor Freight has never let me down. Made in Taiwan, and it's good quality. Reasonable price especially with coupon discounts.
https://www.harborfreight.com/brake-...=brake+bleeder
I may sound like a broken record, but don't forget thee LPSV when you bleed the system for any reason. A lot of folks forget it, and don't bleed it when they do the brakes.
Just a thought.
Pat☺
Just a thought.
Pat☺
The following 4 users liked this post by 2ToyGuy:
YT Community Team
I recently took my LSPV out and diassembled. It was a gunky mess. Cleaned up pretty easily though, there's not much to it once you get it apart.
I just got a compressed air bleeder. Works great, but I needed to put some grease around the bleeder threads to keep it from sucking air
Paul22RE (01-18-2021)
no fluid at either of the rear wheel cylinders with the bleeders open. when i removed the LSPV bleeder, a little bit of fluid dribbled out. i used stripped solid wire to poke into the LSPV bleeder opening, and eventually fluid began to flow out a bit more readily. let it flow until clear, then put the bleeder back in and closed it. at this point, refilled the master, then checked at the rear cylinders; success, fluid now there.
bled the entire system, and have had working brakes ever since. entirely via gravity bleeding.
Ba-dum bum BUMP! (rim-shot, I guess)
I know, stupid joke. Sorry about that.
Carry on, all!
Pat☺
twitchee2
17
02-14-2010 12:39 PM
