Just Seafoamed...
Just Seafoamed...
1990 3.0
Well I just did it. Poured it in through the Brake booster vac line. The idle reved a little and all just like all the hundreds of posts I have read.
Thing is...after the 5min restart....not much if any white smoke. It sure does run better...but I was expecting to FOG out the entire neighborhood like everyone else says they did. Nothing.
I am just telling my self that the engine is extremely clean and didnt really need the Seafoam!
Thoughts??
Thoughts??
yea when i did my 4runner same thing happened. it did a little puff when i first started it. then i reved it up and it smoked a little bit kinda looked like it was burning oil type of smoke and that was all.
I've done seafoam through the induction (pvc) twice now. Both times I was expecting the youtube smokeout we've all seen, and both times I only got a quick puff for like 1 or 2 seconds and thats it. I noticed a a little difference the first time, but not the second. I also run BG44k every 4 months or so and seafoam in the oil for about 30 miles before an oil change. I'll still do it though, all this stuff should be considered normal maintenance IMHO.
how much do you put in? I was questioning if I'm simply not using enough. The second time I did use about 1/3 can and waited about 10 min. Since you smoked only a little the first time I'm also wondering if it took a couple times to work some gunk loose before getting a thorough cleaning.
Did mine today, too. Poured it slowly in through the vacuum line coming off the power brake booster. It started to smoke pretty good before I even got the 3rd of a can in there. Let it rest for about 8 minutes. Started right up and smoked for a few minutes. After clearing all the smoke out, I did notice a better throttle response. The engine was sucking air in thru filter and making that noise like I haven't heard before. Plus I believe that the idle went down by 100 to 650 RPMs. On street performance is still 3.slow, though. Put a can of seafoam in a half tank of gas two weeks ago. Next is the oil. I got 200 miles till my next oil change.
Anybody ever try the seafoam tranny stuff?????
helped my truck after i did it, now it has a jumpy idle sometimes, i sprayed down all the vaccum lines with soapy water but couldnt find anything, only does it sometimes tho so im not to worried about it
I've used on my wife's 97 4Runner, my 90 BMW 735il, and my 2000 Chevy Silverado. All three smoked the entire neighborhood.
Last time I did the Silverado, I pulled over on the side of the expressway at night. I did the treatment then took off after sitting about 9 minutes. It was hilarious.
I did it to my '91 4Runner and it smoked quite a bit and then ran better and had better throtle response but soon after my HG blew and it still is . Actually Im not sure its blown but it sure as hell seems like it. Maybe its not related but now every morning before school I get to see my exhaust smoke like it did after seafoam
The slower you allow it to go in the better it works i think.Also sometimes it can foul out the plugs but that dosent happen very often. I use the same thing at work everyday and most of the time you get alot of smoke.If there isnt alot of carbon buildup though it wont be so bad.
1 Post
If you're doing it on the 3vze, you need to do it through the brake booster line. I did a treatment last night after I noticed the truck running a little sluggishly in the lower RPM's and it made a noticeable difference and it smoked quite well too. It started with the white smoke and then turned it nasty blue smoke like it has in the past.
I think I let the stuff get sucked in faster than most in here would and compared to youtube videos I've seen of different people doing the treatment. I don't do a continuous vacuum of it though, I just dip it in, a little bet gets sucked in, then pull it out, then repeat until the 3rd of a can is gone. In fact I do a third of a can in probably about a realistic 10-15 seconds (pour it into a cup so you can watch it as you suck it up) then reach around and shut 'er off quick. Start 'er up 5-10 minutes later and watch the smoke show for about 5-10 minutes.
Also, last night when I did the treatment, the truck dieseled for about 2 seconds, which usually means there is some gunk in there. When we did my brothers truck for the first time (high mileage 3.4) last year it dieseled for about 10 seconds afterwards.
I have to ask, what does that do to your O2 sensor and cat? It can't be nice. I used it on my engine and noticed no difference. To be objective here, the engine had 8000 miles on it and I had just done the head gasket and cleaned everything but the intake. I later cleaned the intake (with TB cleaner and Seafoam) and the only change I noticed was my idle went up and became inconsistent. Turns out the crap in the intake was blocking the idle air control valve (?) and thus the idle had been opened up more by the previous owner to compensate. I readjusted the idle and problem was solved. Going to give Seafoam another shot sometime though. I also intend on trying "hot soaking" where you suck or mist tap water into the intake. Steam removes carbon build up. Best of all its free.
will seafoam through the pcv hit the IAC valve? I didn't really take note where the vacuum hose ends up. I don't think it would if you put it through the brake booster. I'm referring to a 5vz motor though.
I could be wrong but if my memory serves me correclty, the PCV valve hooks up to the intake manifold. If it doesn't I am pretty sure that it hooks up after the inlet for the IAC. So, I don't think it will hit the IAC. I'll double check when I get home today.
