Just bought an 86' 4runner, need some advice
Here are the problems I'm trying to sort out...
I have a hard time getting the truck started when it's cold. I've read that it might be the cold start injector? The truck starts fine after it's warmed up.
I also tryed to time the truck but according to the crankshaft pulley marking and the degrees marking, it's way off. Should I replace the timing chain? I have it set to where it runs very smooth and strong. Is there something else I need to do besides hook up the timing light to #1 plug wire?
The power steering pump box leaks, should I just replace the seal or the whole thing? Steering seems to have a lot of slack in it. I'm always fighting the truck from drifting all over the road.
The oil pressure gauge doesn't read, is it the sending unit?
That's all the questions I have so far. Thanks in advance.
Originally Posted by AH64ID
Did you do the jumper thingy prior to checking the timing?
Nope. I figured there was a trick to it. On my mustang you pull a pill on the distributor wiring harness to adjust initial timing. Would you mind pointing out a good place that shows me what I need to do?
Anyone have any input on the cold start issue?
http://www.4crawler.com/4x4/CheapTri...CheckConnector
Picture A are the ones you want. They plug in to dead end rubber caps on the driver side fender wall. Mine were just laying there and it took me a while to figure out that they belonged in the rubber holders. Noodle around on 4crawler's site awhile. There is gobs of good info there.
Mike
mine sucked at cold starting for awhile to but i replaced the fuel filter air filter and just tuned everytihgn up and it works great now. I have never heard of anyone having a problem with the cold start injector. As for me i think mine is goig ncrappy as well, When my yota doesnt start cold all i usually do is i have to crank it over holding full throtle. It will rarely start when i hold full throtle. After crankign it holding full throtle if i try to start it with no gas or very little it always will start right up. I mabey have to do this once every 2 weeks though.
Cool. Thanks guys.
What should I do about my power steering having a lot of slack and leaking power steering fluid?
https://www.yotatech.com/forums/show...ing+adjustment
Don't be afraid of that blinking yellow search button. It's your friend.
I have a leaker too and have just been filling it up with fluid periodically for the time being. I bought a used pump off e bay for about $20 to throw in there while I take a crack at rebuilding the original. I haven't found a writeup on the 22re pump but I did find one on the v6. Check it out. I also included a link to a FSM for a '93 someone was kind enough to post for us. It covers tons of stuff for our '86's. Good luck. And welcome to Yotatech BTW.
Mike
http://members.cox.net/stacewilliams/ps-pump.htm
http://personal.utulsa.edu/~nathan-b...fsm/index.html
duckhead
170
11-13-2017 06:07 AM
miah
07-06-2015 06:39 AM
JaredL
06-16-2015 04:47 PM
