irab88's battery/intake swap
Old 04-27-2011, 04:19 PM
  #101
skoti89's Avatar
sorry to ask so many questions. I wont be able to pull enough slack out of the AFM harness. It looks like 7 or 8 pins. is that how many wires? And would I be fine just cutting and soldering each individual wire back together with extensions? I was thinking of rewiring the AFM and the battery cables along the firewall.
Old 04-27-2011, 04:23 PM
  #102
skoti89's Avatar
I actually couldn't tell in all your pics if you were able to get enough of the stock harnes out to extend it, or if you did your option 1
Old 04-27-2011, 04:38 PM
  #103
worshipmentor's Avatar
so did you guys use the stock AFM? (mine is an 87) if so, how do you attach a K&N type filter ive heard in other threads about using a celica AFM?
Old 04-27-2011, 06:24 PM
  #104
irab88's Avatar
i was able to separate the harness enough. pics on the first page
1982 celica supra afm, ending in -43110. it should come with a 3" opening and outlet. if not, there are adapters at advance auto or autozone. it shoul run you about $70 or less. it plugs right in.
Old 04-27-2011, 07:12 PM
  #105
Motox711's Avatar
Any supra AFM will work only the 82 is a direct plug in. I just did mine with a Supra AFM that I got it for 5 bones from my bro-in-law. not sure what year it was off of but i just swapped out the internals(really easy) and it works great.
Old 04-27-2011, 08:55 PM
  #106
4x4climber's Avatar
this is an awesome mod! i am about to do this. just a little different. had a buddy tell me it should be one of my first mods when i got my truck. then gave me the parts off his truck he did it to. Can't wait to start putting my truck together so I can do this mod.
Old 04-28-2011, 06:25 AM
  #107
irab88's Avatar
yeah, you can do that too. a bit more in-depth, but it works well. if i had known that earlier, i would have done the same thing. however, some states don't like seeing an afm tampered with. and for a first-time mod, just using an '82 supra is a good plug-and-play mod
Old 04-28-2011, 02:10 PM
  #108
"some stated dont like seeing......... NOT A PROBLEM IN MS!!!!!
Has anybody done this AND figured out how to feed it cooler air outside the engine bay? I hear the thoughts that getting the feed tube away from the radiator/engine helps but isnt it still sucking HOT under hood air? Even the factory system has a fredh air feed through the core support.
Old 04-28-2011, 02:35 PM
  #109
irab88's Avatar
it's less of a "cold air intake" and more of a "more air intake"
you could run a snorkel. i've wanted to do something like that for a while
Old 04-28-2011, 05:33 PM
  #110
no desire for a snorkel, i dont swim much and neither does my yota. I WOULD however like to have a fresh air intake. I've seen some of them with a cowl feed that comes around the passenger side fender.
Have to agree with ya: MORE air is the object here!
Old 04-28-2011, 11:26 PM
  #111
Aussie22r's Avatar
I've seen some ricers drill a large hole through (70mm) where the battery used to be and run a flexible duct from from there to the bumper. Forcing air in as the car moves. Works really well.
Old 04-29-2011, 04:57 AM
  #112
irab88's Avatar
that's something i actually drew plans for. delivery trucks have a narrow flap that opens into the air stream for cab ventilation. it would be neat to be able to pull a lever and have the door open.
...except when it rains
Old 10-11-2011, 08:47 AM
  #113
richard212's Avatar
dumb question, but what is the point in swapping sides
Old 10-11-2011, 09:02 AM
  #114
irab88's Avatar
Originally Posted by myyota
In a stock set up the AFM is on the driver side, the air intake tube runs across the top of the radiator to the AFM and it picks up a lot of heat. By swapping the battery and intake you get colder air into the intake, and when irab88 swapped the intake over to the passenger side he also upgraded the AFM to a larger one, that will allow the 22RE to breathe better and give you a little more power. Many people here have done the battery/intake swap, as well as upgrade to a larger AFM.
got it?
Old 10-11-2011, 09:41 AM
  #115
cman1's Avatar
irab88, is the PAIR the small thing in your first post pic? what does or did it do ,and did you just plug it off? im all for cleaning up clutter.
Old 10-11-2011, 09:42 AM
  #116
4x4climber's Avatar
Also the run from inlet to t/b is much shorter... which will create better throttle response. Along with it being on the "cold" side of the motor.
Old 10-11-2011, 09:55 AM
  #117
irab88's Avatar
this thing?
yeah, it's the "silencer" for it. the noise without it really annoying. you don't need it, but you do need to keep a filtered air opening on the line (before or after the "silencer"). it's technical name is "resonater", but that's the exact opposite of what it does.
though, if it's a non-smog vehicle, ie a trail only rig, there are kits to remove all that stuff anyway.
Old 10-11-2011, 11:18 AM
  #118
Outsane's Avatar
How has your mileage been?
Old 10-11-2011, 12:44 PM
  #119
irab88's Avatar
got 23 the other night, but all my mileage went back up after the timing chain guide replacement.
in other words, the drop in fuel economy and the b/i swap were completely unrelated.
so yeah, my mileage is great
Old 10-11-2011, 01:01 PM
  #120
Outsane's Avatar
good to know
Quick Reply: irab88's battery/intake swap
