Instrument lights/dimmer problem
Hey guys seems like a minor thing, but I havent been able to figure anything out.
I took apart the dash to install a new cd player, when I put everything back together my instrument lights were at a about 50% brightness. And now the dimmer knob won't change the brightness, they are always just on half brightness. They turn off when I turn my lights off, but I want them brighter like they used to be. What could I have messed up to have done this?
94 4runner
94 4runner
it sounds like you grounded your illumination circuit wrong.
did your stereo have an orange lead for "illumination"? what did you hook it up to?
if you're sure that the radio is wired correctly, it could have a short internally.
typically, when you do something which results in an error, undo it and see if the error goes away. remove the radio, see if it works right again.
i just hooked the illumination lead up to the matching wire. wow, i cant believe i didnt think of that. i'm going to just straight up not connect the illumination. i will disconnect it today and let you know if that helps. thanks
Been a while, I started not worrying about it. But I still cannot get the instrument panel lights to adjust off of their "half-lit" setting. New dimmer switch? New bulbs? I've fiddled with as many wires as I could get my hands on, but nothing effects the instrument panel lights. Email me if you like, I just want bright lights again...
wilamanjaro@hotmail.com
theking11863
03-19-2016 09:36 PM
rushw
07-18-2015 01:46 PM
