Last edit by: IB Advertising
Browse all: Specifications & General Maintenance
- Toyota 4Runner 1984-1995 How to Install Kill Switch
Step by step instructions for do-it-yourself repairs
Installing a kill switch, very easy and cheap!
I read in another post that the guy put a rocker switch under the carpet next to the driver's door. I probably wouldn't put it there (since it's been posted on the internet several times now), but I think that under the carpet would be a good way to hide the switch.
Duh!
Guys, don't be freakin' dumber than the thieves and post where you put your kill-switches- DUH!
But if you insist, please post pics - LOL!
If you dont have a killswitch installed yet, and you have efi, and are parking in a shady lookin area, just yank your AFM connector, engine wont run without it.. Mine doesnt have the little metal clip on it anymore so it just pulls right out, but thieves are lookin for a quick getaway, if your engine just continues to turn over, theyre gonna leave quick.. or if your battery cable is loose enough, yank it off, or pull your coil cable, lots of ways..
#25
I remember my father telling me that at a local small corvette show long ago that a guy removed his coil wire as his kill. The theif used one of the 8 plug wires and drove away.
With our EFI there's a few ways to kill the system easily.
#26
Relay or high Amp switch?
Ok, I'm going to install one but wondering what you guys think about Amp ratings. I have a 3A switch... not sure if I should try and do a relay (I am lost on that one, I would need a lot of help) or if there's a wire that carries little to no amps that won't damage the switch. Or, should I just get a 15A to 20A switch and call it good?
Edit: Nvm answered my own question. The fuel pump pulls too many amps and could risk melting, using a relay.
#29
Find ground wire for coil of the the circuit opening relay and interrupt that with a mni toggle switch. It takes low current. Advantage is you can use a tiny switch. Use double-pole single throw. double-pole means 2 contacts opening and closing in parallel- adds reliability.
Example
Example
That's the exact kind of switch I bought so that will work perfectly.
#31
Just Get Another Toyota To Follow yours around
LOL!
#32
Example
Example
Gonna run a relay instead and splice one of the ignition wires.
#34
Now that he/she knows where the switch is because it is in plain sight, he/she can reach up behind the switch, yank off the wires and just twist them together. Not very effective.
#35
it would be an ignorant assumption to say you could just reach up behind it & yank the wires..who would install it like that? 1st they have to get in the vehicle, discover the vehicle wont start being hot wired, somehow formulate in their mind that one of the 2 keyed switches on the bed box are preventing the vehicle from starting, break into the bed box, get through the electrical conduit, twist the wires together and then hot wire the truck.. all while the 130dB stebel air horn is going off
#36
A few years ago with my old truck I was worried about leaving un-attended all day while we were floating the river all day. I just pulled the efi fuse,and relay and took them with me.
