Idle high in park, normal in drive.
Old 11-30-2015 | 03:35 PM
newzingo's Avatar
Just advanced my timing 2 degrees over factory settings and she runs a lot stronger now, which is nice. But now she idles at about, or sometimes a bit over, 1.5 rpms. When its in drive or reverse it idles at or slightly below 1 rpm. This causes some hard shifts when switching between these gears and I don't want it doing that since I just had the tranny rebuilt a few months ago. Any advice would be great, please and thank you!
Old 12-01-2015 | 07:03 AM
Marc's Avatar
It's always going to be lower in gear.
Did you try putting the timing back to see what happens?
How about if you disconnect the throttle cable.
You're right, it is hard on the drive train.
Also, what the heck are you working on?
Old 12-01-2015 | 07:36 AM
newzingo's Avatar
My apologies. The 3.0. I haven't tried putting the timing back or the throttle. I have the idle screw all the way in though.
Old 12-01-2015 | 07:43 AM
newzingo's Avatar
When it's warm and in park the idle sits around 1100-1200. Maybe I'm just being paranoid. The hard shifting still worries me and the first gear started acting funny yesterday. Occasionally slips when I give it gas. Very jarring.
Old 12-04-2015 | 11:20 AM
newzingo's Avatar
Turns out I'm just a paranoid idiot. lol it's all normal, I just don't know because it's my first Runner. Thanks!
Old 12-04-2015 | 02:39 PM
scope103's Avatar
Originally Posted by newzingo
When it's warm and in park the idle sits around 1100-1200. ...
Spec is 850rpm. There are several limit screws on the throttle valve (to the throttle cable, dashpot, throttle opener ...). If any one of those is in too far it will limit how far the throttle can close. Leading to too-high idle.
Old 12-08-2015 | 12:55 PM
newzingo's Avatar
Tried manually closing the throttle all the way. Brought the idle down to exactly where it should be. I've tried all the screws you mentioned. Nothing helped. Its just barely open too much.
Old 12-08-2015 | 07:34 PM
newzingo's Avatar
Spoke too soon. Adjusted a few things and she's perfect now! Thanks for all the help and advice everyone!
9322rerunner
11-06-2015 05:54 PM
whiseje
11-06-2015 04:30 PM
Volnychev
11-06-2015 07:05 AM
Runnin13s
11-05-2015 07:45 PM
Tharpinator
11-04-2015 05:35 AM
Quick Reply: Idle high in park, normal in drive.
