idle air control valve question??????
I have a 91 toyota pickup 2wd, 22re, standard tranny. I had the iac off the other day to clean and test it my question is should you be able to blow thru both of the nozzles(hose fittings) on it? Mine I can only blow thru one fitting and I tried to even use an air hose on the other but nothing will go thru it so I didn't know if this was the way it was suppose to be or if its stopped up. I aint real up on the function of the iac but isn't coolant suppose to flow thru it? Thanks for any help.
you should have the superior straight plenum/throttle body combo, that uses a mechanical system, here are the differences:
https://www.yotatech.com/forums/f116/iac-valve-226680/
FS[SouthEast]: Mercury Villager Fan & DCC Fan Controller
coryc85
09-09-2015 06:24 AM
Avenged
07-09-2015 07:55 AM
