i could really use some help!
i swaped a 88 3.0 to a 93 as far as i know every thing is all set up right, such as timing, vacuum hoses, ect. the engine cranks over and every now and then it sounds like it wants to fire but nothing. i am stumped!!!!!!!!!!
checked all of the fuses and every thing is good, and i am using the coil out of the running truck. the 88 was a good running truck when i bought it, the body was just rusted out to nothing.
check the feul pump fuse. and make sure the mass air flow senser is all hooked up. check for spark, if you have spark, and still can't get fuel engine, maybe get an air compressor and try to pressurize the fuel tank to help prime the system. those are my first ideas.
1 Post
"jewls" you have my doors you theaf anyways check the afm and tps they both drive the fuel pump i say check the 3 gods
air
fuel
spark
if your missing just one then you go nowheres
air
fuel
spark
